My solution to WOW disconnects
- Gaming
- My solution to WOW disconnects
13-04-2008 2:56 PM
Had a problem with almost instant disconnects from WOW.
System is a reasoanbly uptodate HP running vista and using a Belkin N1 wireless USB adaptor. Modem being a 2wire.
I followed the blizzard solutions to disconnects and unknowns, and also tried everything in the plus.net forums, including new drivers etc.
Tried a wired connection to the router and it ran fine. Tried wireless but with a different wireless connection and it still didn't work. Came to conclusion that it was an issue with the router and not vista. Swapped it for a £50 linksys model (WAG54GS) and it now works perfectly, and my wireless connection is slightly faster.
No disconnects since and I have been running it for 24 hours now.
For the horde !!!
For the horde !!!
1 REPLY 1
Re: My solution to WOW disconnects
23-04-2008 12:58 AM
Quote WAG54GS
Be sure to check the firmware on that thing, I had serious problems with the original firmware on one of these causing the wireless to lose it's bridge to the lan, and the ppp connection to drop - if in doubt, check with linksys.
