Lagging on PSN
- Gaming
- Lagging on PSN
Lagging on PSN
25-10-2011 12:57 PM
I have upgaded to plusnet fibre, and Im getting a lot of lagging while playing online on PSN.I am using what was supply to by plusnet which is Netgear WNR1000, i have tried a variety of setting like , DMZ , set a static IP adress for the PS3 , tried defaut setting swithch on and off upnp on the router and nothing seems to have sought out the lagging. Surfing the web is fine and dont have any disconnecting problems just the lagg on PSN.
I am using wireless and my signal is 80 to 87 so its not the wifi strength.
Any advice will be much appreciated
![Smiley Smiley](/html/@39650D28FE4EA73A5BA77CFD0A477003/images/emoticons/smiley.gif)
Re: Lagging on PSN
26-10-2011 8:26 AM
![Cry Cry](/html/@6B4B63041062049E874E6843927E9ADE/images/emoticons/cry.gif)
Re: Lagging on PSN
26-10-2011 12:10 PM
Your speed profile on our side was wrong limiting your speed to ADSL speeds. I've just changed that now, let me know if that seems better.
Ex-Broadband Service Manager
Re: Lagging on PSN
26-10-2011 12:52 PM
I let you know if it has made any different
dick:quote
Re: Lagging on PSN
26-10-2011 6:34 PM
Re: Lagging on PSN
27-10-2011 5:36 PM
Re: Lagging on PSN
27-10-2011 5:48 PM
If not, then you probably have a fault which we can look at getting raised for you:
![](http://ccgi.psmith12.plus.com/visradius/generated/image13197340274335.png)
Re: Lagging on PSN
27-10-2011 7:03 PM
I allso done a speed check and seem to only to get around speed around 5MB down load and 1MB upload.
dick:quote
Re: Lagging on PSN
27-10-2011 7:08 PM
Re: Lagging on PSN
27-10-2011 7:17 PM
i will buy you drink if your graph is worse than my avg VM 30mb stats
http://www.thinkbroadband.com/ping/share/88d6556776027a75001ac5e45413b280.html
and thats a good day
Re: Lagging on PSN
01-11-2011 9:52 AM
Im gonna leave my router and modem on and connected at all time now, i usually turn them off at night when i go to sleep.
Hopefully that will solve the lag on psn, if not i mute have to buy a new router to see if it helps , i just have the feeling that the router is restricting something when i play online ?
Re: Lagging on PSN
10-11-2011 9:36 AM
The only time it has gone off was after i updated the setting , like DMZ the PS3 to see if it would helped but still no luck.
I have gone back to fefault setting and have decided to buy a new router to see if it will help.
Re: Lagging on PSN
11-11-2011 9:38 AM
Also keep your ps3 in DMZ as it is more likely to keep your NAT type as open, which is preferable.
Re: Lagging on PSN
14-11-2011 8:29 AM
dick:quote
Re: Lagging on PSN
15-11-2011 6:20 PM
Only thing i can think i can do is get a new router, hopfully it will solve this lagg that is anoying so much
