Lagggggggg!
stef1989
Lagggggggg!
I always seem to get lag whenever i'm on Fifa 17 on the Xbox One. It used to be fine but the last few weeks has been driving me crazy! If the wife uses the tablet for Netflix then it's almost impossible to play as even replays lag!
Moderator's note by Mike (Mav): All caps title edited as per Forum rules.
7 REPLIES 7
Kelly
Fixes: 9
Re: Lagggggggg!
Is it only Fifa17 affected? Or all games? Is it only when another computer is doing something? Or does it happen when only you are generating traffic on the network?
Kelly Dorset
Ex-Broadband Service Manager
ghos7
Re: Lagggggggg!
sorry to jump on this thread but i have exactly the same problem, all other games are fine.
Kelly
Fixes: 9
Re: Lagggggggg!
@ghos7 Did your issues just start happening as well?
Kelly Dorset
ghos7
Re: Lagggggggg!
mostly for me on fut champs. ill get speed up lag.players running slow and take ages to react.
Kelly
Fixes: 9
Re: Lagggggggg!
@ghos7 @stef1989 Still having problems?  Have you raised a support request?
Kelly Dorset
ghos7
Re: Lagggggggg!
i played fut champs today still same problem. think it could be the plusnet hub as other family members complaining of lag and disconnects. we have 2 xbox ones 1 pc and rest are phones. im using upnp only. did speed tests and speed is fine.
stef1989
Re: Lagggggggg!
It's only on Fifa that i have lag. Sometimes it's running perfectly and then for no reason is just lags all the time. Everything else works fine on the phones, Netflix and other games.
I'm leaving as i'm moving house so let's hope Virgins 200mpbs is better Smiley
