Lag spikes on Xbox S
- Gaming
- Lag spikes on Xbox S
20-08-2023 6:27 PM
So I don’t know if they are called lag spikes. But when I’m playing fifa or over watch on my Xbox. The game freezes for a split second then rapidly speeds up. For the second I’ve missed. It’s not an Xbox fault is obvisouly to do with the router/broadband. Every other device seems fine all over the house. Does anyone have a fox for this either through Xbox settings or logging into the router? I’ve already switched off 2.4ghz and just use 5ghz.
Thank you
Thank you
1 REPLY 1
Re: Lag spikes on Xbox S
20-08-2023 6:39 PM
Have a read of this topic for ideas and how to test your connection - https://community.plus.net/t5/My-Router/No-firmware-updates/m-p/1930762#M35895
