Is interleaving still a thing?
OryxCallotis
Was wondering about this, I remember you could ask to have interleaving turned off if your connection was rock solid.
Is this still a thing (and can I ask for it to be turned off if so too lol)?
2 REPLIES 2
Fixes: 585
Re: Is interleaving still a thing?
On FTTC , interleaving is completely controlled by the Openreach DSLAM in the cabinet and ISP's have no control. Interleaving does not exist for FTTP connections.
When I was with BT Broadband, I remember that the Hub's GUI showed if Interleaving was on or off, (I used to check it because we were having a lot of issues with our line at the time), but I can't seem to find it on my Plusnet Hub.
Does the Plusnet Hub2 show the status of Interleaving, (where?)?
