High PING
Ray77
High PING
I do not know what is wrong,but my PING  to Maidenhead is now (this week) about 100ms.
Last week 30ms. I have interleaving off.
Can somebody help me?
7 REPLIES 7
Fixes: 1,473
Re: High PING
the speedtest ping is very unreliable - can you try pinging news.bbc.co.uk, that is probably a better indicator of your ping.
Ray77
Re: High PING
How can I do it?  Sad
Euge
Re: High PING
bring up dos
start --> Run
type 'cmd' enter
at prompt type ping bbc.co.uk
edit: sorry, or news.bbc.co.uk
but it makes no odds
scootie
Re: High PING
sure you havent got any thing uploading in the background.
these are the sorts of pings i get when iam using more than 80% of my upload total
Pinging bbc.co.uk [212.58.224.138] with 32 bytes of data:
Reply from 212.58.224.138: bytes=32 time=174ms TTL=122
Reply from 212.58.224.138: bytes=32 time=18ms TTL=122
Reply from 212.58.224.138: bytes=32 time=166ms TTL=122
Ray77
Re: High PING
It looks ok.  31ms
thx
Ray77
Re: High PING
What is TTL there?
You have 122 and I have 58.
spraxyt
Aspiring Legend
Fixes: 75
Re: High PING
TTL is Time To Live, a network setting for the maximum number of hops a packet is to take before the journey is given up as a dead loss. The TTL count reduces by one for every hop traversed, and the packet will be discarded when the count reaches zero. This is a protection against packets entering an infinite loop.
It looks like one computer sends packets with TTL=128, the other 64. Normally anywhere to anywhere is no more than about 30 hops (usually far fewer) so either number is satisfactory.
David
