Help / Tips for gaming
- Gaming
- Help / Tips for gaming
30-01-2015 6:58 PM
Hi, ive been plusnet for about 4 years now and overall its been a pretty bad experience. I got Plusnet under the assumption it would be great for gaming, but over the last year and a half its been impossible to game at anytime of the day. I'm meant to be getting 7-12mbps but im stuck in the region of 2-3.5mbps, which means all the games i play online are lagging. I
2 REPLIES 2
Re: Help / Tips for gaming
04-02-2015 4:56 PM
Prob best to raise a fault if your speed has dropped that much. Suggesting tips is pointless if you have a fault.
Once fixed there is another existing thread on configuring your connection/router for improved gaming experience, so prob read that.
04-02-2015 5:17 PM
As Mathias suggests, there is something wrong with your line at the moment. Have a look at the graph below to see the number of disconnections on your line:
![](http://community.plus.net/visualradius/generated/image14230701538810.png)
I'd strongly suggest going through the faults process at https://faults.plus.net so we can have a look at this. I can see you did have a fault open a few days ago, but it looks like you closed this on our website.
