Gaming Mode - On or Off???
- Gaming
- Re: Gaming Mode - On or Off???
18-03-2014 8:59 PM
Should gaming mode on the router settings be enabled or disabled for best performance with use of Xbox One?
What are the positives and negatives to having this enabled?
Regards
Marc
19-03-2014 1:01 PM
Having your router in Gaming Mode should open up the most common ports required for gaming. If you ever have any NAT Type issues, using Gaming Mode can sometimes help.
There aren't any drawbacks as such, if you are using a Games Console, you may notice a better experience with Gaming Mode enabled
19-03-2014 3:08 PM
17-06-2014 1:53 PM
17-06-2014 6:13 PM
What is your view on putting the PS4 into a DMZ on the router?
17-06-2014 7:54 PM
18-06-2014 1:16 AM
19-06-2014 10:55 PM
How do you go on if you have more than one device and want both of them in a DMZ?
Foe example, I have a PS3 and PS4. Putting the PS4 in a DMZ is easy, just make sure I select the right connection through the IP identifier in the list of connected network devices, and make a note of the IP number (I take a picture of the big screen TV with my mobile for that) and then just select the DMZ option in the router settings and again make sure it's the right IP address and hit the "Enable" button on the rooter.
However, after doing that, the button is then greyed out? Does this mean we can only have one PS in a DMZ at a time, and that I have to fire up the PC in order to change the settings each time to DMZ either the PS3 or PS4?
Thanks in advance for any help.
19-06-2014 11:15 PM
21-06-2014 10:56 AM
Oh dear, then thought of having to run upstairs every time I want to switch from the PS3 to the PS4 to enable then disable the DMZ because of swapping console game play is making me quiver.
If that's the case then Gus, should I be running the Technicolour in "Gaming Mode"? And will that work when I am using either the PS3 or PS4, obviously not both at the same time, but will that do anything for me?
Many Thanks.
21-06-2014 11:51 AM
21-06-2014 3:07 PM
