FIFA 12 reply
- Gaming
- Re: FIFA 12 reply
FIFA 12 reply
08-03-2012 7:40 PM
i know this could be peak times! Im wondering if theres any solutions to this Problem.. I know theres port forwarded etc.. But personally it wont be any different .. i'm fine in the day i have No disconnects atall.. its perfect its just 7 till 11 its terrible .. I Would be happy to pay a little extra to avoid this problem. i've also heard interleaving turned off helps? Thanks reply if you Can...
kevinneill
Re: FIFA 12 reply
08-03-2012 9:25 PM
Have you checked the status of you exchange here http://usertools.plus.net/exchanges/
I know it's a little out of date but it shows my exchange as currently red and I have similar problems to yourself.
Re: FIFA 12 reply
08-03-2012 9:44 PM
Re: FIFA 12 reply
08-03-2012 9:57 PM
Re: FIFA 12 reply
08-03-2012 11:04 PM
Could you post your router stats here.
Re: FIFA 12 reply
08-03-2012 11:43 PM
View more...
Uptime: 0 days, 0:05:51
Bandwidth (Up/Down) [kbps/kbps]: 444 / 2,560
Data Transferred (Sent/Received) [kB/kB]: 115.00 / 432.00
INTERNET
View more...
Type: PPPoA
Uptime: 0 days, 0:05:49
IP Address: 31.185.177.56
Data Transferred (Sent/Received) [MB/MB]: 20.77 / 63.11
Re: FIFA 12 reply
08-03-2012 11:45 PM
hope that was what you were wanting? sorry i'm a basic guy
Re: FIFA 12 reply
09-03-2012 9:18 AM
Ex-Broadband Service Manager
Re: FIFA 12 reply
09-03-2012 10:41 AM
Re: FIFA 12 reply
09-03-2012 11:34 AM
Re: FIFA 12 reply
09-03-2012 11:56 AM
Turning interleaving off probably won't help in this scenario and might make your line more unstable, but we can try it if you are sure.
Re: FIFA 12 reply
09-03-2012 12:07 PM
Will Plus Net Pro avoid this problem ?
Re: FIFA 12 reply
09-03-2012 12:14 PM
Re: FIFA 12 reply
09-03-2012 2:41 PM
Not sure if these disconnections are down to you rebooting the router or not, but if they're not I would strongly recommend keeping interleaving on as without it the drops will happen more often:
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13313039229637.png" />
I'd recommend making sure the router is plugged into the master socket and that everything else that's plugged into the phone line is done so through a microfilter, and if the line is stable for at least 72 hours then we'll look at turning interleaving off for you.
Re: FIFA 12 reply
09-03-2012 2:51 PM
i'm now sticking with the router you guys supplied me.
