Black Ops 3 PS4 Nat Type Strict
domino211998
Hi.
As the title says, I've had a problem with my NAT Type on COD BO3 on PS4, not allowing me to join my friends. When I go to the network settings in multiplayer, it says that the game tried to get through port 3074. Is this any help? My router is the technicolor TG582n.
Thanks in advance.
2 REPLIES 2
MisakiKim
Re: Black Ops 3 PS4 Nat Type Strict
Same thing here even though it uses these
PS4
TCP:    80, 443, 1935, 3480
UDP:
TCP and UDP:  3478-3479, 3074, 3075
I even had my ps4 in the dmz my router is sagemcom plusnet 2704n
Doglet
If you enable UPnP on your router it should punch a hole through your router automatically.
Or setup the port number in port forwarding on your router.
