Black ops 3 for ps4
anisasarwaya
Black ops 3 for ps4
my nat type is stict for black ops 3 and i cant join any of my friends do you have any solutions which can fix this please help
3 REPLIES 3
Starmans
Re: Black ops 3 for ps4
What router are you using?
panthor
make sure you have the 'gaming' option ticked in your router settings.  Also you could do what i did and give your ps4 a static IP and place it in the DMZ
Doglet
It means it can't punch a hole through your router to host matches, you should still be able to play as a client though.
The simple way to solve it is to enable UPnP on the router. This does weaken the security a bit.
The more complex old fashioned way to fix it is to enable port forwarding on your router for your game.
