slow speeds
vorlon99
slow speeds
dont know whats ahppening tonight but my speeds are varying from 15-35 if i,m very lucky, huge lag spikes making gaming almost impossible . supposed to be 60
http://mybroadbandspeed.speedtestcustom.com/result/3cbdad50-8869-11ec-9f62-6146335647e7
38 REPLIES 38
Fixes: 384
Re: slow speeds
@vorlon99 You obviously have a problem, but we need a little more information to help you:-
For Community members to be able to help, information from these two sites, as screenshots:-
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (ethernet) connection. Please report the 'ADDITIONAL DIAGNOSTICS', and sight of the HELP DESK tab from your Hub would be a start.
If phone test is OK then take the front off your telephone master socket, you may need to remove two screws. In behind you will find the test socket. Plug a filter in here and connect that to your hub. If it’s still dropping out then report a fault at https://faults.plus.net.
Fixes: 1,662
Re: slow speeds
Thanks for your post @vorlon99
I'm really sorry to see you're having speed issues.
I've tested your line today and the tests aren't showing any issues with your router getting a stable, good speed of 65mbps.
I'd agree with @jab1. Can you confirm if you're testing on a wired connection or wireless?
Mav
Fixes: 518
Re: slow speeds
Moderator's note(s):
Thread moved from ADSL Broadband to Fibre Broadband.
Forum Moderator and Customer
vorlon99
Re: slow speeds
is a wired connection to the master socket
vorlon99
Re: slow speeds
i dont think a speed test has ever given me 65, and as you can see by the test I shared, not even close.
Fixes: 384
Re: slow speeds
@vorlon99 OK - that test does show a lower speed than expected, but as stated by @Gandalf , you are getting a speed of 65Mb/s to your HUb, so the issue lies somewhere after that. If you supplied the information I asked for in post #2, we may be able to see what is happening. You say 'it's a wired connection to the master socket' - is it a wired connection from your PC to the Hub?
vorlon99
Re: slow speeds
yes,wired master socket to the hub then wired to pc
at work now so will try the other test later
Fixes: 384
Re: slow speeds
OK - understood.
vorlon99
Re: slow speeds
back home again and its back up to 55, weird?
Fixes: 384
Re: slow speeds
Maybe a transient issue, @vorlon99  - but posting the requested info from my original reply could determine the cause/possibility of it reoccurring?
adam945
Fixes: 113
Re: slow speeds
 Line speeds are currently coming through at around 68.35 Mbps @vorlon99, I'll pop a graph graph below. Which router are you using? I've just tried to log into the Hub One on your account but it's offline?
Are you able to access the data rate on your router's hub manager at all? It should show you the current sync speed.
 Adam
 Plusnet Help Team - Leeds
vorlon99
Re: slow speeds
its a tp link ac1200
odd though, i cant connect to the router. the message says computer is correctly configured but resource not available.
perhaps thats the problem?
vorlon99
Re: slow speeds
Fixes: 384
Re: slow speeds
@vorlon99 Do you still have the PN Hub ? If so, is it possible to temporarily switch to that for diagnostic purposes? Some of these other modem/routers are somewhat deficient when looking for information, although I don't understand why you can't access yours.
