slow speeds
vorlon99
Re: slow speeds
Not any more and dont have a spare unfortunately. time to get a new one? recommendations? (inexpensive)
Fixes: 95
Re: slow speeds
@vorlon99
TP- Link AC1200 just refers to the up to wifi speeds the device supports. ( 5Ghz - 867 Mbps & 2.4Ghz - 300 Mbps)
Another TP-Link DSL Modem/Router !?
With most TP-Link devices the advanced status page has an overview of the xDSL connection.
If you can not access the router Landing Page I suggest try switch off and on, if that fails a factory reset might be required using the pin hole near the LAN ports.
HTH
Dan.
vorlon99
Re: slow speeds
Hi Dan, its been turned on and off a couple of times, will try the reset when I get home  but need a back up plan.
my wife works from home and she and others have said they have had random disconnects. but I also use wired plug adaptors for the 2 other connections
Fixes: 95
Re: slow speeds
Are the random disconnects with the power adapter connected devices or devices connected directly to the router or wifi?
In some situations powerline adapters can be temperamental, not that I have found them so.
All speed tests should be performed on a wired device connected directly to the router.
Dan.
vorlon99
Re: slow speeds
to be honest I dont know as I only found this out yesterday. I cant take the risk with the router, so I'll get a new one for del tomorrow and swap when I get home. just looking for recommendations.
LaurenB
Fixes: 131
Re: slow speeds
Hiya @vorlon99, as @jab1 has mentioned, I would recommend connecting to your Hub One if you still have this, it will also help to rule out any problems with your current router.
 Lauren Barry
Fixes: 297
Re: slow speeds
@LaurenB - see post #16
vorlon99
Re: slow speeds
Fixes: 95
Re: slow speeds
You will need a modem for that device to work fully.
Title clearly says 'Cable Router'
Dan
Fixes: 297
Re: slow speeds
And, to follow @Dan_the_Van 's comment, I hope the description is a load of rubbish - only 802.a wireless and WEP security - on  Wi-Fi6 kit???
Yea, noticed the 'Cable Router on re-reading, Dan.😀
Fixes: 95
Re: slow speeds
Here are a selection of ADSL/VDSL TP-Link modem routers
https://www.tp-link.com/uk/home-networking/dsl-modem-router/
Dan.
vorlon99
Re: slow speeds
thanks for the catch, did not even notice
vorlon99
Re: slow speeds
up and running again, thanks for the help guys
vorlon99
Re: slow speeds
would you belive it, still doing it, getting a bit annoyed now.
vorlon99
Re: slow speeds
