constant disconnection
Reaper51
Hello,
Ok this seems now to be an ongoing problem I have contacted you before about the same issue last time I was sent a new hub on seemed to fine all was working now today I have yet again had 3 drop outs with noise on the line when picked up but have a feeling that will soon go away is anyone able to have a look into this for me.
Thank you in advance
4 REPLIES 4
Fixes: 387
Re: constant disconnection
@Reaper51 Noise on the line? - report a phone fault.
Fixes: 1,662
I'm really sorry to see you're having connection issues. I've tested your line tonight and the tests are indeed showing a fault so I'd like to call out an Openreach engineer for you to take a closer look.
Could you reply to the ticket I've created on your account Here with when you'll be available for an engineer visit? If you can post back once you've done so, I can make sure we book the engineer as soon as possible.
Fixes: 1,495
Moderators Note
This topic has been moved from ADSL Broadband to Fibre
adam945
Fixes: 113
Hello @Reaper51
I've just responded to the open ticket on the account if you'd like to have a look. Let us know, on here, when it's been responded to and we'll pop back into the account to get things sorted. Smiley
 Adam
 Plusnet Help Team - Leeds
