Xbox series x not connecting to network
Alistair12
Xbox tries to connect using multiple Ip addresses at the same time but router admin page shows it connected as static ip address which seems to change by itself. I've tried everything to fix this problem. Has anyone any ideas on a fix
2 REPLIES 2
outcast
Re: Xbox series x not connecting to network
Is the router showing more than one IP address because the Xbox is connecting by ethernet AND WiFi ?
Alistair12
Xbox is connected by ethernet cable and is showing wired connection. Plusnet advisor sent list of ip addresses it was trying to use. The xbox itself kept flashing up different addresses. Router management page showed static ip address.
