Worth getting Hub 2 router?
shesawsparks
My current full fibre contract is due to end soon and I'm probably going to renew it. I currently have the Hub 1 router and was just wondering if it's worth upgrading to the Hub 2 router? What's the difference between them? If you've gone from the Hub 1 to the Hub 2 do you think it was worth it?
3 REPLIES 3
Fixes: 382
Re: Worth getting Hub 2 router?
How long have you had full fibre?
Fixes: 117
@shesawsparks
The Hub2 has better WiFi but you can't spilt the bands.
Fixes: 382
But you can turn off the 5Ghz band if needed.
