Which ethernet port connecting to (ONT)?
FIXEDTopic Options
- Full Fibre
- Re: Which ethernet port connecting to (ONT)?
20-05-2024 11:04 AM
I have a Hub 2 already using some of the ports, does the ONT connect to the red WAN port, or does it use one of the precious 4? Awaiting install, I'm wondering if I need to buy kit to ensure uninterrupted access. Am already likely to have a cabling issue around the house.
Fixed! Go to the fix.
Message 1 of 4
(1,196 Views)
3 REPLIES 3
20-05-2024 11:06 AM
The ONT does connect to the WAN port for FTTP.
Message 2 of 4
(1,193 Views)
20-05-2024 11:08 AM
@Norrette there is only 3 plus the red WAN port
Message 3 of 4
(1,191 Views)
20-05-2024 11:15 AM
Thanks folks and ... I must get new glasses! 😂
- Full Fibre
