Which box do I connect plusnet router too ?
Dave27
Hoping someone can help ?
Switching from BT fibre (they attended my house and fixed Fibre box the below the Master socket
So when my Plusnet router arrives do I connect to the box that I currently get fibre through or the master socket above ?Huh
So confused
14 REPLIES 14
RichardB
Seasoned Champion
Fixes: 39
Re: Which box do I connect plusnet router too ?
Hi @Dave27
Connect the Plusnet router same way as the BT router.
Regards
Richard
Fixes: 111
@RichardB
The BT router will also work if you change the login credentials.
RichardB
Seasoned Champion
Fixes: 39
Agreed but BT demand their routers are returned after leaving BT on pain of being charged.
Hence, the advice.
RealAleMadrid
Fixes: 68
@Dave27 Have you actually changed to FTTP (full fibre) If you have you will have an Openreach ONT installed, is this what is below the old master socket? You were not getting full fibre from the master socket, probably fibre to the cabinet.
If you have the ONT you connect your Plusnet router WAN port to the ONT with an ethernet cable, the old master socket is no longer in use, I hope you realise that you no longer have a phone service, Plusnet do not provide that on their full fibre product.
@Dave27
If you are still confused about what type of broadband service you have, can you post a photo of the master socket and the "box underneath it"?
Dave27
Thanks, I would but don’t know how to upload the photo don’t seem to have the option to ?
Dave27
Dave27
Think that’s it
Can anyone else open the link that @Dave27 posted in Message #8?
I'm getting an "Item not found" error.
Champnet
Fixes: 19
Fraid not....
willcutforth
Fixes: 113
I tried as well and I am seeing the same as @Anonymous
 Will Cutforth
Fixes: 111
@Dave27
When you reply to a message you get a list of options above the message box. If you choose the rectangular box with a mountain in it you can post the image in the body of the message.
Fixes: 145
In addition to the above, if you are using a smart phone or tablet when replying to a post you need the browser to use 'Desktop Site" or words to that effect
HTH
Dave27
Ok, thanks for the patience I’ll try from a desktop as my mobile does not give me the upload photo option
