Very slow upload speeds
Rostik
Hi, recently I noticed that my upload speed has gone down tremendously and I have no idea why. I thought it would go away after a while but it didn't. My download speed is fine, great even (500Mbps), but the upload speed can't even go past 1Mbps.
https://www.speedtest.net/result/14887707817
Also I didn't know where to post this but here I am now.
Edit: I tried restarting my router but that didn't help.
5 REPLIES 5
Fixes: 1,495
Re: Very slow upload speeds
Moderators Note
This topic has been moved from Broadband to Full Fibre
bill888
Champion
Fixes: 40
Was the speed test over ethernet or wifi?
Do you see low upload speeds with another device?
Fixes: 580
Not a Killer NIC is it ? https://community.intel.com/t5/Ethernet-Products/Killer-Intelligence-Center-Slow-Upload-Speed/td-p/1...
Rostik
It was on an ethernet connection, and it was the same on my phone too.
Also after making this thread, a couple hours later my internet shut off by itself for a couple of minutes and then turned on. I checked the speeds and it seemed to have fixed itself?
Rostik
Honestly I've never heard of this and I don't think I have this
