Very slow internet
Michael199
Very slow internet
Normally the internet for me would be around 80 mbps - 100. now its literally under 10 and its been like that for the past 2 hours. The wifi is so horrible this happens so often. This issue occurs every week for very long periods of time. Ive restarted my router around 4 times now and no changes.
Tags (1)
3 REPLIES 3
Fixes: 387
Re: Very slow internet
@Michael199 From your quoted 'usual' speeds, I am guessing you are on FTTP (Full Fibre). If so, have you noticed any change in either the ONT or Hub lights when this slow-down occurs?
Fixes: 480
Moderator's note:
Thread moved from Plusnet Feedback to Full Fibre.
Tags (1)
Fixes: 480
@Michael199   Welcome to the Plusnet Community Fora.
Would it be correct to assume that this is a wireless connection? If so, what is the speed when connected over an Ethernet cable?
