Upload speed
James30
Fixes: 32
Re: Upload speed
@Notoriousxx  we're still waiting for the order to complete from outside. I take it there is no improvement? In the old Openreach FTTC modem days, we could setup a PPPOE connection directly eliminating the router from the equation. I'm thinking the Openreach ONT will work the same if others can confirm and it would be worth trying to get connected that way instead to eliminate the router be it the hardware/firmware perhaps. Here @ https://asahi-net.jp/en/support/guide/os/pppoe_win10.html shows the setup for win 10 but similar on other operating systems, use your username @plusdsl.net and your broadband password to authenticate it.
James - Plusnet Sheffield
Notoriousxx
Re: Upload speed
There has been no change yet. I will check tonight when I'm back from work though.
I will also try the method you have suggested. I'm not sure if that would work on android devices though, only Windows I'm guessing?
Fixes: 579
Re: Upload speed
@James30 it will, however you need a machine with a wired network capability that can make a PPPoE connection.
Yep, not sure how you're going to do that on an Android device...
James30
Fixes: 32
Re: Upload speed
@Notoriousxx  - Do you have a Windows/Mac computer you could borrow?
Notoriousxx
Re: Upload speed
Oh, I do have PCs, I just meant if that would be a permanent solution then my android devices wouldn't work with that suggestion I guess?
I'm on the way home now so I will test if anything has changed and report back.
Fixes: 579
Re: Upload speed
It's not a permanent solution, it's just a test to eliminate the router
Notoriousxx
Re: Upload speed
No change in speed I'm afraid.
Why would the router be at fault?
Notoriousxx
Re: Upload speed
Still no difference this morning.
I didn't get to do the troubleshooting yesterday as something else cropped up, but I shouldn't really have to be doing things like that as the broadband should just work as intended and as I'm paying. I've had nothing but issues since the plan started.
James30
Fixes: 32
Re: Upload speed
@Notoriousxx  I understand, I'm sorry for the hassle. We're struggling a bit to find where the issue is and we don't offer a minimum guaranteed speed for upload. Just an estimate, unlike the download. Can you let us know when you have been able to set up a connection on the PC using a PPPOE connection so we can be sure that we're not dealing with any strange firmware or compatibility issues with it.
We're also waiting for Mat W to return to clarify what he meant by modifying the connect as the notes aren't clear. If the authorities allow modifying your provisioned upload to something higher would be interesting but this order seems to be stuck, if we don't hear back from you about the PPPOE test then we'll get back to you Monday 1st April with details of this modify Mat has processed.
Notoriousxx
Re: Upload speed
In my "Welcome to Plusnet" email, it states my upload speed should be minimum 27mbps, not 20.
RealAleMadrid
Fixes: 68
Re: Upload speed
@James30  The OP raised this issue on the 11th of February, Plusnet seem to be dragging their heels on solving it and now you say you will get back on Monday the 1st of April, why such a delay? You should be able to find out what modify order Matt W placed and chase it up.
Notoriousxx
Re: Upload speed
Thanks for this. I do agree they are taking their sweet time. In the contract summary it says if Plusnet cannot resolve my issues within 30 days then I am entitled to cancel without penalty. It has been more than 30 days now. My network was activated 6th Feb!!! I was told the network increase would be Monday and then put back to 145 Tuesday to see if this resolved the issue!!! I shouldn't have to be doing network tweaks to rule out router issues. It's ridiculous and inconvenient for me.
Fixes: 245
Re: Upload speed
Other than the figures being "not right" is this giving rise to a material impact on your use of the internet?
Notoriousxx
Re: Upload speed
Yes, actually.
Edit to add.
On occasions, the network fluctuates from 145 to 60. As well, as I am paying for a speed of minimum 27 upload and have only ever experienced 20.
I just want an explanation, if I can get more than 20 upload, I will be satisfied. I am not getting answers from anyone despite raising this on the forum as well as ringing customer services.
Fixes: 245
Re: Upload speed
Would you care to share?
