Upload speed
Re: Upload speed
After eight weeks of anticipation, the moment when  @Notoriousxx  does a speed test with 30Mbps upload -
Notoriousxx
Re: Upload speed
Re: Upload speed
It's good to see FINALLY that you got the speeds you signed up for !  Cool
@Notoriousxx wrote:
Why is it a C though?
Because you are using a Hub-2 which is poor at managing latency (the Hub-1 was better !)  Cry
If you want to achieve an "A" or "A+",  and not suffer lag spikes, then you will need a different router that supports QoS, CoDel, Cake, or SQM , to perform traffic management on upload and download to tune out any bufferbloat.
For online gaming a "B" rating (latency < 60ms) is probably about as bad as you'd want it. ("C" is latency < 200ms !) Shocked
Notoriousxx
Re: Upload speed
Ah, I see. The only worry I have is I did the BT Wholesale test to see what my speed was set to and it said upload 45mbps, so I'm thinking was this that thing Matthew did to increase it then decrease again to see if it fixes it? Before the BT test said I was getting 30upload when I was getting the 20...
Oh I see. My Mum has the eero mesh 6, but her WiFi supports WiFi 6...
Fixes: 240
Re: Upload speed
There is a body of evidence which suggests that at FTTP speeds QoS is detrimental to optimal through put.
Re: Upload speed
I'd be interested to see the bufferbloat grade of that, as I've never known anyone to have that before -
Screenshot 2024-04-06 at 22-21-54 Bufferbloat and Internet Speed Test - Waveform.png
Notoriousxx
Re: Upload speed
I'll try to get a test when I next visit. She gets unlimited 400down and 40up for £20 a month.
Unfortunately, her provider isn't in my area otherwise I would have been all over that.
Re: Upload speed
? ? ? - it's an Amazon product !
It looks like there are new versions available - Amazon eero
Notoriousxx
Re: Upload speed
Oh yes, I was just having a little complain about Mum's network being better than mine haha 😅
I will definitely consider the eero. I'm just happy I'm getting my 30upload finally.
Re: Upload speed
It will be interesting to see if her eero works better than this - Amazon Eero Pro 6 and Gigabit SQM
Re: Upload speed
For what it's worth, this is my FTTC connection today, using a pfSense router -
Screenshot 2024-04-06 at 17-55-09 Bufferbloat and Internet Speed Test - Waveform.png
Re: Upload speed
Some say that using broadband without QoS is like the Stig driving a car with the handbrake not fully released !  Cheesy
Notoriousxx
Re: Upload speed
Would I need to get more than one eero?
Re: Upload speed
The Amazon product pages give the WiFi coverage area for each model.
It will depend where you put the unit, what your house is made of, what you neighbour's WiFi is like, etc...
It's probably worth borrowing you Mum's, trying it connected to your ONT, then wandering around and checking the WiFi signal.
Notoriousxx
Re: Upload speed
Thank you, I will give that a try 🙂
