Upload speed
Mav
Fixes: 518
Re: Upload speed
Moderator's note(s):
An unnecessary post removed.
Forum Moderator and Customer
Notoriousxx
Re: Upload speed
Thank you, PlanetX.
I have had a response via email from member of the Customer Advocates Team, which I have been told there is a potential fault on my line and they have reported it to BT which can take 48 hours, I will await a response... 🤞
corringham
Seasoned Champion
Fixes: 23
Re: Upload speed
@Notoriousxx,  I fear that from Plusnet's perspective the important part of the response is "can take 48 hours" - so they get another few days of not having to do anything about your issue.
Re: Upload speed
@Notoriousxx
It is difficult to imagine how a "fault on your line" would let your ONT upstream sync at 30Mbps but only allow speed tests to pass EXACTLY 20Mbps upload throughput.
Sounds like [-Censored-] to me,
if only you had a  [-Censored-] detection meter !  (if Mav hadn't removed it !)
"can take 48 hours" takes you into the weekend with at least two days of no support, and then maybe another three days before support get a reply from Openreach.  So you'll be back asking for an update this time next week !
Moderator's note by Mike (Mav): Avoidance of swear filter edited as per Forum rules.
corringham
Seasoned Champion
Fixes: 23
Re: Upload speed
@Anonymous, I think you are correct that this can't be a "line fault" as the BT test showed it is syncing exactly as expected. It is somewhere beyond that in the network that the upload appears to be capped.
if only you had a  B S detection meter !  (if Mav hadn't removed it !)
Ah, I was wondering what had been removed!
bobpullen
Fixes: 330
Re: Upload speed
To play the pedant, there is no concept of 'sync' where FTTP is concerned.
I'm interested in the outcome of the attempt to modify the speed of the circuit. Only read back a few pages but did that get anywhere?
It's not outside the realms of possibiliity that something between the Openreach and Wholesale networks is misaligned, and having the circuit regraded again might kick something into touch.
Notoriousxx
Re: Upload speed
There hasn't been any update or fix at all from this post until I raised a complaint last night and a Customer Advocate Team member responded to me today: "Upon testing your line there is a potential fault and so I have raised this to Openreach who have advised this can be rectified external to your property, though at this point there is no further information as to the issue and whether this would have a direct effect on your upload speed."
RealAleMadrid
Fixes: 68
Re: Upload speed
@bobpullen  It would appear that the upgrade order was "stuck" (msg #130 24th March) which is 10 days ago and Openreach have not managed to do much since apart from kicking their 48 hour updates down the road.
bobpullen
Fixes: 330
Re: Upload speed
Can't promise anything but I'll take a quick look at things tomorrow if I get a minute.
corringham
Seasoned Champion
Fixes: 23
Re: Upload speed
Yes, I'm aware of that but it is how support report test results. Rather like stating that it takes 10 days for the speed "to settle".
What do you think the chances of an OR test detecting such a "misalignment" are?
Notoriousxx
Re: Upload speed
Well, I have news...
Shockingly, I am now getting 30upload upon doing speed tests, this has been since I raised the complaint and the Customer Advocate Team member contacted me.
Wonder what they did to resolve this and what the issue actually was. I'm keeping an eye on the speeds though to see whether it's a fluke...
corringham
Seasoned Champion
Fixes: 23
Re: Upload speed
I wonder why they couldn't have done whatever it was sooner.
Fixes: 383
Re: Upload speed
@Notoriousxx Wonder if @bobpullen kicked something (or someone)?
Re: Upload speed
@Notoriousxx ,
for the record, can you post a screenshot of the LATENCY and SPEED results using Waveform speed test
or post here the "Share Your Results" link
Notoriousxx
Re: Upload speed
Of course. I will do that when I am back home tomorrow.
