Upload speed lower
Sguk
Upload speed lower
Just upgraded to full fibre, all fairly ok apart from a blown brick to repair and the silly policy of having the grey box at ground height where anyone has access to the cables then going all the way back up the wall into the first floor 🤷‍♂️. Not good for security!
However, the reason I’m posting is that on 145/30 at our other address uploads are 30mb
on this new connection uploads are 28. Anyone else have this issue?
14 REPLIES 14
Fixes: 376
Re: Upload speed lower
The CSP has to be installed at ground level as  the splicing kit cannot be used at height.
Upload speeds are never guaranteed - even on FTTP installations.  A 2Mb/s difference will have very little effect on experience.
Sguk
Makes sense.
They wouldn’t put the cable on the inside of the garage pillar (6 inches away) either so I guess the cables have to stay visible too.
Agreed with the upload, it’s more the reasoning. Fttp isn’t best effort as on the higher packages it’s 75+ so effectively it could easily be 30 on the 150 package like our other property.
Fixes: 376
They couldn't put it on the inside as the door could trap and damage the cable.
As regards upload - that is, as I say, never a guaranteed speed, and you won't notice a difference - unless you do more uploading than downloading, and even then it is negligible.
Sguk
I run datacentre hosting platforms. I’m aware of uploads thanks.
and regarding the cable, no it wouldn’t trap it. No one with any sense would suggest that.
its a pilar with three sides.
they ran the cables on the outside not the inside which would have been more secure. The doir is fixed to the end of the pillar inside the frame.
Fixes: 376
I run datacentre hosting platforms   - at home?
OK.
RobPN
Fixes: 14
@Sguk wrote:
... and the silly policy of having the grey box at ground height where anyone has access to the cables then going all the way back up the wall into the first floor 🤷‍♂️. Not good for security!
@Sguk
That's the main reason I had my CSP installed indoors with the cable entering the loft under the eaves.  All fibre cables are safely indoors apart from the section from the pole to a point 5-6 metres above ground level.
Bella123
Did they mount the CSP in the loft?
Was it easily accessible?ie rafters boarded, headroom
RobPN
Fixes: 14
No, it's installed in a downstairs utility cupboard via approximately 17m of conduit which I'd pre-installed.
The ONT is mounted on the wall of the room above via a couple of metres of a second conduit.
markhawkin
Aspiring Champion
Fixes: 21
On the same "Full Fibre 145" as you I see 150Mb/s down and 29Mb/s up.
Plusnet give the package details as:
  • 145Mb estimated download speed
  • 80Mb minimum guaranteed speed
  • 30Mb estimated upload speed
I'm mildly puzzled that the upload isn't called 28Mb/s in the package details so that both directions are slightly "over provisioned" but I assume it's a marketing thing.
Sguk
Sguk
Good point!
One of our addresses gets 28, the other gets 31 on the same package. They say it's the network, but if I was paying for a higher package, they'd give twice the speed, so really there's no excuse.
However, as it's only slight I let it be : )
Sguk
OK.
No. At a datacentre.
Remote access 24/7 from locations including home. Yes.
Understands uploads. Yes, 20yrs since dial up times.
Cheers
Sguk
@RobPN wrote:
@Sguk
Ideal! Mine has been moved into the garage now, on the inside of the door pillar instead of the outside, so at least the cables only come half way down the house.
Sguk
@Sguk wrote:
@RobPN wrote:
@Sguk
Quinn wouldn't move it so I contacted Openreach CEO and high level team directly. They got it sorted.
