Upgrading delay?
Dbgreen
Upgrading delay?
Just upgraded my fibre package from 150mb to 500mb, activation date on the email was for yesterday but still no change, can anyone clarify if it only switches over once I’ve next been billed or is there something wrong here?
36 REPLIES 36
Fixes: 585
Re: Upgrading delay?
As far as I am aware, the change should happen immediately and the next bill will adjust pro-rata for any increased charges.
Perhaps it needs a router reboot to trigger a change in IP profile on re-establishing a new PPPoE session ?
Fixes: 585
The account change should trigger a PPPoE drop.
Fixes: 1,665
It looks like your upgrade is happening today, so the change should be completed by tomorrow morning.
Fixes: 480
Moderator's note:
Thread moved from Broadband to Full Fibre
@Anonymous
"Perhaps it needs a router reboot to trigger a change in IP profile on re-establishing a new PPPoE session ?"
I'm guessing from the speeds quoted, the OP is on FTTP?
If that is the case, then I thought that any change in speed profile would be changed within the ONT, rather than the router - which should always be syncing with the ONT at 1000Mbps, even if their current contract speed is "only" 150Mbps? So rebooting the router wouldn't achieve anything in this case?
Or, have I misunderstood how FTTP works?
@Anonymous  my "thought" was that possibly (I don't know) that any new IP speed profile update "might" need to be triggered somewhere along the existing FTTP connection route, perhaps in the ONT, or the exchange where the FTTP terminates, or Plusnet handover point, etc
Therefore my suggestion of rebooting the router, was to force a new PPPoE session to be established over the entire route, in the hope that whatever needs changing IP profile gets triggered.  I wasn't expecting anything locally at the home router to change, because as you say it will always "see" a 1Gbit WAN connection to the ONT.
As a suggestion, it is something that @Dbgreen could do themselves, would have been quick and cost nothing to try, and if it had worked would have meant that they wouldn't have to contact Plusnet support, and unlike a router reboot on ADSL or FTTC there is no chance of DLM down-rating the FTTP connection.
As it turns out, the speed upgrade hadn't been applied yesterday as expected, but hopefully should complete by tomorrow.
Fixes: 585
@Anonymous very likely. The connection is initially partially authenticated by the BTw concentrator ( using the BBEU and PN username ) which then routes the connection to the PN gateways for full authentication. I suspect the connection to the BTw concentrator would need to be remade to pick up any new profile.
@MisterW  I hadn't previously spotted that BBEU is in plain sight in the router's PPP logs !
Feb 4 13:29:00 	ppp 	97055 	[wan_link0] MESG: BBEUxxxxxxxx 74678000/20000000
that log entry has inadvertently answered a question that I had been pondering over earlier this week, so thanks for the nudge !
I had been trying to make sense of all the various data rate numbers associated with my SoGEA connection, but hadn't figured out exactly where that "74678000" number came from, as it shows up in my ISP's "Control Panel".  I've just realised that that is my connection's actual raw line rate, and fits in the speed profile hierarchy as follows -
   Modem attainable speed = 78608120
  Modem actual sync speed = 78243000
            PPP line rate = 74678000  : 95.4% of modem sync
  BT Wholesale IP Profile = 72500000  : 97.1% of line rate, or 92.7% of modem sync
ISP traffic profile (95%) = 69643694  : 96.1% of IP profile, or 93.3% of line rate
I'll have to take a closer look at my ISP's traffic profile, which I manually set to 95% (to allow prioritised incoming VoIP packets through), but the numbers suggests I actually have 96%.
The other download numbers that I've still not squared with anything, are those that come back from performing a BT "end-to-end" test on my VDSL connection, resulting in -
BT Test E2E Access Test/DCN:Pass OR test pass. No fault found.
Down: 74.9 (77.7 / 78.9 / 79.9)
Up: 20.0 (20.0 / 20.0 / 20.0),
0.128M-80M Downstream, Retransmission High - 0.128M-20M Upstream, Error Protection Off
Any ideas what any of  "74.9 (77.7 / 78.9 / 79.9)" refer to ?  Huh
Fixes: 585
@Anonymous
Off the top of my head, no! but I'll have a think.
I'm a tad surprised the BBEU is visible ?
I realise its not a PN connection but is it a BT wholesale provider ?
AIUI the BBEU is inserted into the PPPoE (or DHCP for TT/Sky) negotiation by the DSLAM (for VDSL) and the OLT(for FTTP), so Im not sure how the router would get it ?
Yes a BT Wholesale provider.
The BBEU log entry looks to me like an informational message received by the router after successful CHAP authorisation -
Feb 4 13:29:00 	ppp 	97055 	[wan_link0] LCP: authorization successful
Feb 4 13:29:00 	ppp 	97055 	[wan_link0] CHAP: rec'd SUCCESS #1 len: 34
Feb 4 13:28:59 	ppp 	97055 	[wan_link0] CHAP: sending RESPONSE #1 len: 30
Feb 4 13:28:59 	ppp 	97055 	[wan_link0] CHAP: Using authname "my-account-name"
Feb 4 13:28:59 	ppp 	97055 	[wan_link0] Name: "name-redacted"
Feb 4 13:28:59 	ppp 	97055 	[wan_link0] CHAP: rec'd CHALLENGE #1 len: 72
Feb 4 13:28:59 	ppp 	97055 	[wan_link0] LCP: LayerUp
Feb 4 13:28:59 	ppp 	97055 	[wan_link0] LCP: auth: peer wants CHAP, I want nothing
Feb 4 13:28:59 	ppp 	97055 	[wan_link0] LCP: state change Ack-Sent --> Opened
Feb 4 13:28:59 	ppp 	97055 	[wan_link0] MAGICNUM 0x5ea84fd7
Feb 4 13:28:59 	ppp 	97055 	[wan_link0] MRU 1492
Feb 4 13:28:59 	ppp 	97055 	[wan_link0] LCP: rec'd Configure Ack #10 (Ack-Sent)
Fixes: 585
Interesting...
I'll try some debug or wiresharking on my connection when I get time. Although mines  an FTTP connection ,  yours is SoGEA I assume ?
Most of my information on pppoe and bbeu came as a result of this thread https://community.plus.net/t5/My-Router/PPPOE-authentication-with-Plusnet-FTTP-not-working/td-p/1910...
Fixes: 118
@Anonymous
What causes [wan_link0] ?
I've had a look at my FullFibre PPP event log and can't see any examples of the above.
Fixes: 585
I don't think @Anonymous is using a Plusnet router
