Hub Two - stuck on green light
Suarez
This morning my Hub Two router changed from blue to green, cutting off all connectivity.
I've tried turning off and on again, but the green light remains.
I followed the FAQ for solutions, and then tried to factory reset with a paper clip, but the light just remains green. I held in for 20 seconds +.
How do I fix this?
Thank you.
16 REPLIES 16
Fixes: 334
Re: Hub Two - stuck on green light
What are your ONT lights showing? If they are all green, I suspect a fault with the Hub.
Suarez
They are green except LAN.
Suarez
Oh wait, LAN green again.
Suarez
And now LOS is off.
All 3 others on.
Fixes: 334
OK. I would suggest my initial thought is correct. Best bet is to call Plusnet.
Fixes: 334
@Suarez wrote:
And now LOS is off.
All 3 others on.
LOS being on - green? - would suggest a fault in the OR network. Having said that, my understanding is that should be 'off' if the network is OK.
Suarez
Will do. Thanks.
Suarez
LOS was always off. I was being dim sorry.
Fixes: 530
Just for info, LOS will never be green. Its either OFF (normal) or RED (fault).
@Suarez as @jab1 says , you've got a faulty router. Green is only shown during startup, so that implies its not starting up properly, hence its likely faulty. Call Customer services, they should arrange a replacement
Fixes: 334
yep, sorry @MisterW - I know LOS is either off or red, the OP got me a bit confused.😀
Fixes: 530
and you'll get to see it in real life soon...
Fixes: 334
Hopefully LOS = permanently 'OFF' 😀
RobPN
Fixes: 13
My ONT doesn't have a LOS light.
It has an 'Optical' which seems to be dual-purpose, so under normal circumstances it is green but goes red if the service is down.
Admittedly it is a fairly old 4-port version which has been in place since 2015.
Fixes: 530
That's a 'blast from the past'!
It would appear that your Optical light is a combination of the PON and LOS lights on the later ONTs
Normally PON is GREEN , going OFF when a fault detected
