Updated cabinet
David_Haigh
Updated cabinet
So just had our cabinet updated for FTTP and WBC is now available. Does anyone know availability of the trial and current costs for it, as I believe there will be a reprice in Feb 2018?
Cheers
David
9 REPLIES 9
Aspiring Hero
Fixes: 33
Re: Updated cabinet
Do the results say "WBC FTTP" in the left hand column? Post a picture if you can.
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
David_Haigh
Re: Updated cabinet
Hi Brian,
Yes the "WBC FTTP" says available.
Regards
David
Aspiring Hero
Fixes: 33
Re: Updated cabinet
David
The picture came through as a txt file with no detail.
Just to be clear if you have "WBC FTTP" is the left hand column there should be a further column headed "FTTP Install Process" which will have "1 stage" or "2 stage" in it - one visit or two.
David_Haigh
Re: Updated cabinet
Hi Brian
Try the PDF.
Mustrum
Fixes: 73
Re: Updated cabinet
That is FTTP on Demand, a very expensive product which PN don't provide.
It is very unusual to be able to get FTTP if you can get FTTC.
Strat
Fixes: 565
Re: Updated cabinet
The pdf shows you have FTTP on Demand available (left hand column), a service not offered by Plusnet due to the very high costs involved.
Mustrum got in first.
Aspiring Hero
Fixes: 33
Re: Updated cabinet
David
As other's have pointed out you can't get FTTP. You can get FTTC (VDSL) and looking at the speeds shown on the DSL Checker you should get a very good service. PlusNet offer 38/10 or 78/20 I believe.
Login to PlusNet and follow the upgrade links if you wish to change - or you could try phoning them (I gather calls to their Sales team get answered far more quickly than Support calls!!!).
runhare
Re: Updated cabinet
yes - as I discovered it costs ££££'s and PN don't offer it .
We all have to wait until the lower cost standard FTTP roll out. Sometime never!
Fixes: 1,550
Re: Updated cabinet
Hi David. Unfortunately, as others have advised there's just FTTP On Demand that's available. Due to the very high costs of the install, this isn't something we'd offer I'm afraid. Apologies for any disappointment caused.
