Todays News from BT
FIXED- Subscribe to RSS Feed
- Full Fibre
- Re: Todays News from BT
19-01-2018 1:48 PM
@David_Haigh wrote:
So an extension box on the side of the CAB could be G.force ...
Just thought you might need a reminder ...
19-01-2018 5:25 PM
@Browni Mine has non of the aforementioned clutter on the front, so the extension is just more twisted pair.
19-01-2018 7:08 PM
"g.force" may the force be with you
20-01-2018 5:53 PM
@krusty the Clown,
More like g.farce the way it could be rolled out!
22-01-2018 1:25 AM - edited 22-01-2018 1:44 AM
If you're already getting half of the fibre speeds when g fast enabled will you get half the speeds from the max speed?
22-01-2018 9:05 AM
You need to be getting close to full FTTC speed i.e. 80/20 to get any benefit from G.Fast. So the cabinet based G.Fast roll out is only going to benefit houses within say 200-300 metres of the cab. It seems to be a quick fix so BT can offer speeds comparable to Virgin Media but only for a limited number of homes.
22-01-2018 6:53 PM
It's still very early days for G.fast and as such there is very little data available.
22-01-2018 7:01 PM - edited 22-01-2018 7:07 PM
If the FTTC sync rate @ 79999k and must be within between 25m and 175m then it will benefit from it, BUT, if it was more than 175m away then you are out of luck with g.fast.
My GEA Test say my line estimate length in metres are 248m away from the FTTC, so, it a NO NO for my g.fast as it will slower than FTTC.
This is why g.fast is very poor rolled out in my view by Openreach as around 55-75% will not benefit from it because of the FTTC cab are further distance away.
One thing is why can't Openreach leave uncapped speed on all FTTC removed 80Meg capped so the line can go faster as possible from the FTTC cabinet to the property if g.fast is much lower than FTTC estimate range.
22-01-2018 7:12 PM - edited 22-01-2018 7:14 PM
22-01-2018 7:15 PM - edited 22-01-2018 7:16 PM
Yes that for speed estimated range for FTTC. But slightly less on g.fast because g.fast work best on very short distance from the FTTC cabinet with a stone throw in.
I think under g.fast with 248m away the speed estimated for g.fast are probably below 55Mb or less.
22-01-2018 7:32 PM
My FTTC stats example with 248m away depend on SNR & attainable rate:
SNR: 18.0dB - 113000K
SNR: 15.0dB - 103000K
SNR: 12.0dB - 93000K
SNR: 9.0dB - 83000K
SNR: 6.0dB - 73000K
SNR: 3.0dB - 63000K
That's for non-target 3dB SNR by Openreach on FTTC
22-01-2018 7:32 PM - edited 22-01-2018 7:36 PM
Edit: I see you've already read it. FWIW, it mirrors what I've seen with the test lines we've provisioned.
22-01-2018 7:39 PM - edited 22-01-2018 7:46 PM
Thanks for this @bobpullen So it look like I probably getting around 200/30 with approx 250m for g.fast. Look like the product from BTwholesale 152Mb / 29Mb for g.fast are likely to be capped at 152/29. Other option for 314/49 will be no chance for me.
100m 500 Mbps 50 Mbps 11%
150m 300 Mbps 45 Mbps 20% 200m 250 Mbps 40 Mbps 31% 300m 150 Mbps 20 Mbps 52% 370m 100 Mbps 20 Mbps 64%
23-01-2018 2:04 AM - edited 23-01-2018 2:05 AM
23-01-2018 10:14 AM
I was surprise that Openreach wouldn't do a new profile 30a with vectoring for the FTTC especially those who live further distance away and maybe slightly better than g.fast that need to be much closer to the street fibre cabinet.
Profile for FTTC below:
Profile name Bandwidth used (MHz) Maximum speed (Mbps) 8c 8.5 50 17a 17.664 100 30a 30.0 200
