Time outs and emails replies
pvmb
Aspiring Champion
Fixes: 14
Re: Time outs and emails replies
"Make it make sense....."
If only.  🤣
Fixes: 378
@Dan_the_Van wrote:
@atom33
I'm unable to view your links without having to save them to my pc first....That doesn't seem right.
This is expected, your virus checker would scan the files before downloading the to the ./Download folder.
I thought attached, rather than embedded files should be visible once downloaded, @Dan_the_Van  - or has something changed again, to frustrate those of us trying to help who don't have SU/mod status?
Fixes: 145
@jab1
 I do not need to be logged in, for me the file is download and opened, should not need to be released to be viewed
Fixes: 378
Thanks for confirming, @Dan_the_Van . No idea what @atom33 's problem is , then.
atom33
3.Hub2 broadband.png3.Hub2 broadband.png4.Hub2 eventlog.png4.Hub2 eventlog.png5.Hub2 technical.png5.Hub2 technical.png
Fixes: 145
@atom33
why did you attach those three images, they were to guide you to where to look on your hub two for the information required
Fixes: 378
Beat me to it, @Dan_the_Van .
atom33
Thanks - that was really helpful.......I  see "uptime" is  a dash.....meaning?
atom33
"- I moved straight from an 'unsafe' - according to MS - W7 one to Linux, ".......I purchased this one because it had a large enough hard drive that if needed it could be partitioned and Linux installed.......Are you happy using Linux?  You're the first I've encountered using it....
Fixes: 378
I'm outta here I thought i had said in message #27 that those files were, as @Dan_the_Van has confirmed, merely guide you, pictorially, to the required screens.
Fixes: 378
I will never go back to Windows. And before you ask, I only switched ~6 years ago.
atom33
I added 3 images as 3 images were shown to me by John.....looking at the page, and not knowing what info you needed, and seeing that the bottom of the page is cut off at a readable size...I then did what John did and copied 2 of the first page.....showing top and bottom........
Simple.  There is usually a sound reasoning behind my madness....
atom33
"Can you attach screen shots from you Hub of the two example in the attachments below "   You asked and supplied 3 images....I responded - I don't see the problem.
Fixes: 378
Sorry - I thought you would understand that they were merely visual guides - obviously not!
cpc6128
@atom33 Do your replies get stuck in the drafts folder? Does Mailbird think the e-mail you are replying to or your draft is spam?
