Third party router setup??
terrapin
Can anyone point me in the right direction as to how to configure a third party router for use with PLusnet?
My internet connection keeps dropping and is only reset when I call Plusnet support and they do a line test..... they say that that the router is losing synchronization possibly due to static on the line (??????).
Anyway, thought I would try to use a different router.
2 REPLIES 2
EmilyD
Aspiring Hero
Fixes: 117
Re: Third party router setup??
Hi @terrapin,
I'm sorry to hear that you've been experiencing dropping connection problems.
To configure a third party router you will need to consult your manufacturer or your manual to gain access to your router and find the necessary pages.
Encapsulation Type:PPPoA (PPP over ATM)  if on ADSL broadband PPPoE (PPP over Ethernet) if on fibre
Username: your account [email protected]
Password: Your account password
Multiplexing Method:</b> VC-MUX
VPI:</b> 0
VCI:</b> 38
Please let us know if the connection problem persists with the new router.
 Emily D
Fixes: 115
@terrapin
The settings required can be found in the PlusNet Help pages
https://www.plus.net/help/broadband/broadband-connection-settings/
