Connection constantly drops when it is windy and raining
FIXED- Subscribe to RSS Feed
- Full Fibre
- Connection constantly drops when it is windy and r...
07-12-2018 10:26 AM
Hello Support
My broadband connection consistently drops when it is windy and raining. When the weather is fine the connection is stable but on a day like today when it is raining quite heavily and is windy it drops every few minutes, reconnects then drops again.
I did have an engineer out for this once before but he came to my house and tested the connection when the weather was good and said he could find nothing wrong.
I think there must be a damaged cable running to my house from one of the telegraph poles that is effected when it rains but I am not sure how this can get looked at? There is no point in sending an engineer to my house to look as there is nothing wrong with the internal cabling and the chances are, if the weather is good then he will find nothing wrong.
I’m assume you can see the constant disconnects and reconnects on my broadband to help validate this?
Any help would be appreciated.
Michael
Fixed! Go to the fix.
07-12-2018 3:47 PM
Hi @sheavesm and welcome to our forum!
Please accept my apologies for the issue with your broadband connection.
After testing the line, I have detect a potential external fault and raised this to our suppliers. They have advised us of an estimated response time of 24 - 72 hours. You can monitor the progress of the fault via this ticket and our faults team will be back in contact shortly after the estimated response time.
Feel free to get back in touch if we can be of further assistance in the meantime.
Thank you.
Re: Connection constantly drops when it is windy and raining
08-12-2018 11:15 AM
Great, thanks for your help...
08-12-2018 6:39 PM
Hi
Look to see if the cable is touching / passing any tree branches, this can cause issues.
1. removing the insulation which will then affect the phone service due to reduced voltage.
2. Fibre (well hybrid fibre) uses radio frequencies, trees and metal poles are not good.
27-01-2019 11:29 AM - edited 27-01-2019 11:29 AM
Thanks for your help.. after two visits by BT they replaced one of the external cables and it has been fine since...
Apparently the cable that ran across the street to the telegraph poll was "50 years old" and "Brittle"..
27-01-2019 10:24 PM
i.ve had same thing for past 18 months, line checks, engineer on site etc etc but never found any faults, even though broadband drops out at least 10 times a day, in fact today has a record for dropping out 27 times all for a minute or two each time what can be done to fix this intermittent problem as am getting a bit fed up with it now, and being told each time thees no problem, obviously there is a problem or it wouldnt be dropping out on a regular basis, windy rain, passing traffic all knock it out
28-01-2019 12:14 PM - edited 28-01-2019 12:15 PM
Hi @mojacarkev,
I'm very sorry that you have been experiencing connection drops and for the length of time that this issue has been ongoing.
I can see from your connection log that it's been dropping frequently:
However, testing your line isn't picking up the cause of this from here:
| GEA Test Detail | |||
| Circuit ID | NA | Service ID | BBEUXXXXXXXXX |
| Test Outcome | Pass | ||||
| Test Outcome Code | GTC_FTTC_SERVICE_0000 | ||||
| Description | GEA service test completed and no fault found . | ||||
| Main Fault Location | OK | ||||
| Sync Status | In Sync | ||||
| Downstream Speed | 64.2 Mbps | ||||
| Upstream Speed | 16.6 Mbps | ||||
| Appointment Required | N | ||||
| Fault Report Advised | N | ||||
| NTE Power Status | PowerOn | ||||
| Voice Line Test Result | Not Run - Unable to run | ||||
| Bridge Tap | Not Detected | ||||
| Repetitive Electrical Impulse Noise | Not Detected | ||||
| Estimated Line Length In Metres | 639.9 | ||||
| Upstream Rate Assessment | Very Good | ||||
| Downstream Rate Assessment | Very Good | ||||
| Interference Pattern | Regular Interference Observed on Weekends | ||||
| Service Impact | Retrains Observed | ||||
| Interference Duration Longest Occurrence | From 06:15 to 06:30 | ||||
| Interference Location | Unknown | ||||
| Home Wiring Problem | Not Detected | ||||
| Downstream Policing Discard Rate | 0.0 | ||||
| Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
| Technology | VDSL | ||||
| Profile Name | 0.128M-80M Downstream 4dB, Retransmission High - 0.128M-20M Upstream, Retransmission High | ||||
| Time Stamp | 2019-01-15T12:15:00 | ||||
| Parameters | MIN | MAX | AVG |
| Down Stream Line Rate | 63.2 Mbps | 69.0 Mbps | 64.5 Mbps |
| Up Stream Line Rate | 16.5 Mbps | 17.9 Mbps | 17.4 Mbps |
| Up Time | 836.0 Sec | 900.0 Sec | 899.2 Sec |
| Retrains | 0.0 | 2.0 | 0.0 |
| Current and Last 15 Minute Bin Performance | ||
| Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
| Start Time Stamp | 2019-01-28T11:59:54Z | 2019-01-28T12:14:54Z |
| Ingress Code Violation | 0 | 0 |
| Egress Code Violation | 0 | 0 |
| Errored Seconds | 0 | 0 |
| Severely Errored Seconds | 0 | 0 |
| Unavailable Seconds | 0 | 0 |
If you've not done so recently, please can you run through our troubleshooting guides here and let us know how you get on? If these checks don't resolve the problem, the next step would be to rule your internal wiring out by plugging the connection into your test socket which is under the faceplate of your master socket and seeing if the drops stop. This rules out internal wiring, face plates and extension sockets as being the cause. Please see the guide here for instructions on how to connect to the test socket.
If your connection continues to drop when the router is connected to the test socket, please report the issue here and get back in touch on here once you've done this - we'll then be able to investigate this further for you.
05-03-2019 1:19 PM
I have the same problem more or less. My fibre broadband drops out when it starts tom rain but returns a few moments later even if it is very wet. Annoying when you are watching catch up. Line test shows no sound.
Can you advise?
05-03-2019 1:23 PM
05-03-2019 1:39 PM
Yes, sounds familiar. Very thorough OR visit ( sig. gen. at skt and signal strength monitored to distribution pole) revealed a bimetallic joint between old and new lines. Immediate improvement obtained. Since then speeds have dropped from 49 to 43Mb/s in 'rough' conditions so I suspect there are further connection problems. I'm tolerating it so far due to other priorities.
05-03-2019 3:01 PM - edited 05-03-2019 3:02 PM
Hi @Tandleman, sorry to hear you're having connection issues. Checking from this side there certainly looks to be something out of place somewhere given the drops we've seen over the last few days shown on the graph below.
Upon testing your connection it looks to have highlighted a fault. As it's advised by our suppliers to arrange an appointment to the property we would advise getting your router in the optimal set-up your side and letting us know after doing so. At which point we can re-test and if the issue persists get the fault raised and a engineer out with no worry of the problem being caused by internal wiring.
| Test Outcome | Fail |
| Test Outcome Code | GTC_FTTC_SERVICE_1625 |
| Description | Impairment in copper joint detected most likely in local network. Please continue to submit a trouble report |
| Main Fault Location | CE |
| Downstream Speed | 40.0 Mbps |
| Upstream Speed | 10.0 Mbps |
| Appointment Required | Y |
| Fault Report Advised | Y |
| Voice Line Test Result | Pass |
| Radio Frequency Ingress | Not Detected |
| Cross Talk | Not Detected |
| Estimated Line Length In Metres | 601.7 |
| Technology | VDSL |
| Profile Name | 0.128M-40M Downstream, Error Protection Off - 0.128M-10M Upstream, Error Protection Off |
| Time Stamp | 2019-02-20T14:45:00 |
Getting the router in the optimal set-up would require plugging the connection into your test socket which is under the face plate of your master socket and seeing if the drops stop. This rules out internal wiring, face plates and extension sockets as being the cause. How to locate the test socket and set your connection into it can be found here:
https://community.plus.net/t5/Library/Testing-From-The-Master-Socket/ba-p/1322242
By all means once in this set-up if you reply to this thread we'll happily re-test and see if we need to raise a fault and get a engineer out to investigate further. Let us know how it goes.
05-03-2019 3:08 PM
Hi @mojacarkev, as highlighted by my colleague, if you could follow the troubleshoot steps and optimal router set-up and if the issue persists to raise a fault and let us know as we'll happily progress this forwards for you.
05-03-2019 3:30 PM
25-04-2019 3:20 PM
Hi
I've been away and it hasn't really rained much here. Yesterday it did around 17.00 and the connection dropped out immediately. I have done the master plate thing and it has made no difference.
Can I have this checked again and I need a fault raising.
Cheers
Peter
25-04-2019 3:51 PM
It has justb thunderstormed and the connection has gone again.
- Full Fibre
