Switching problem
yipykayay
Switching problem
I’m looking to switch back to Plusnet after a long hiatus. I was hoping to order online to qualify for a £125 reward card through MoneySupermarket but there is an error and I need to call Plusnet to proceed.
The error is due to an address mismatch between the Royal Mail PAF and the Openreach database. Openreach have advised to ask my current supplier to raise an ORDI request.  I’ve tried that but Sky are sending me round in circles.
So I have 2 questions…
1, Will I still qualify for the reward card if I place my order over the phone?
2, Would Plusnet then be able to raise the ORDI request to get the mismatch fixed?
Thanks in advance
3 REPLIES 3
Fixes: 251
Re: Switching problem
There is a process (in ALBERT) for addressing this, though the person you speak with might need pointing at that process.
As for the reward card, you will have to ask when you phone up ... the staff around here probably do not have the knowledge to answer that question.
yipykayay
Thank you
ExForce9
All Star
Fixes: 11
@yipykayay
You might be able to get that looked at sooner using this form -
.           https://www.openreach.com/forms/fibre-broadband-availability---customer-form
Please only use this form if you've already used our availability checker to get
information about broadband in your area and you think that the information provided
isn't accurate or is incorrect.
