Suddenly No internet connection
FIXEDTopic Options
- Full Fibre
- Re: Suddenly No internet connection
03-09-2021 1:01 AM
My internet suddenly stopped working today starting at 00:40am. The router (Plusnet Hub One) is showing a red light and red "b". I did try restarting the router by power off and power on it a few times but it's still showing red lights. I have also unplugged everything and plugged it back but it still showing red light and red “b”.
I have checked the router setting and the DSL line status is fine. I can see that the Line status is Connected. However when I go to Internet connection configuration page, the connection information is disconnected.
Could you please urgently help. Thanks.
Fixed! Go to the fix.
Message 1 of 3
(10,625 Views)
2 REPLIES 2
03-09-2021 8:16 AM
- Try a factory reset of the hub by pushing a paperclip or similar in to the reset hole and hold the switch closed for about 30 seconds.
- Leave it 10 minutes or so and see if that fixes it,
If that doesn’t work:
- Log in to the hub by putting 192.168.1.254 in the address field of your web browser.
- On the broadband page (I think, you may need to look through the pages to find it, depending on which hub you have) you should find the username. If it’s [email protected] then it hasn’t configured itself.
- Remove the DSL cable.
- Change the username to your account username in the form <username>@plusdsl.net.
- Enter your account password.
- Plug the DSL cable back in.
- If it doesn’t try to connect select Connect (again you may need to look through he pages to find it).
Message 2 of 3
(10,592 Views)
03-09-2021 8:28 AM
Hi Baldrick1,
It is working now after I followed your instructions. Many thanks!!!
- Full Fibre
