Sudden drop in download speed
brazclapz
  • Product: Unlimited Fibre Extra
  • Minimum Guaranteed Speed: 57.1Mbps
  • Current Line Speed (Download): 33.6Mbps
Hi all,
since last night I have noticed that my download speed has gone from a consistent 8-10mb to 3-4mb.
In the router it is stating that the downstream is now at 34.93Mbps. I've had no issues in over a year besides a few dropouts for a few minutes. Is there any staff that could look into this for me?
Thanks.
14 REPLIES 14
Fixes: 357
Re: Sudden drop in download speed
@brazclapz PN staff will no doubt catch up with this soon, but if you would like a  slightly quicker response 😉, this might help:
Can you report the information from these two sites:-
BT Broadband(obscuring your phone number) and BTW Performance Tester - Please report the 'Additional Diagnostics', and sight of the Help Desk tab would be a start.
It may also be a good idea to report the results of a Quiet Line Test - dial 17070 option 2 from a (preferably corded) phone. After the confirmation of you phone number, there should be total silence apart from the regular 'Quiet Line Test' announcement. Any other noise - report a PHONE fault first.
brazclapz
So I ran a quiet line test & that's fine.
Fixes: 357
You certainly hava problem there, @brazclapz . Can you post your 'Help Desk' tab from the router please? Unfortunately, the last test date on the Availability Checker is way out of date, so no help.
brazclapz
.@jab1
Moderator's note by Dick (Strat): Personal information removed from a public forum (to an area that staff can see).
Fixes: 357
Thanks for that. Something is way out of line there - your D/S data rate is way below what it should be, the D/S SNR is way too high, and - unless you are intentionally switching the modem/router off - your DSL uptime is suspiciously low.
I'm afraid there is nothing I can do further as a Community member, but hopefully one of the Help Team who are around can run the relevant check from their end.
adam945
Fixes: 113
Hello @brazclapz
Thanks a lot for reaching out and I'm really sorry to see the sudden drop in sync speeds on your line. I've run some tests today which clearly show nothing wrong until yesterday, when all of a sudden, the speeds tanked. Going forward, please complete the Broadband Troubleshooter which you started this morning, and in the "Additional Information" section, pop in some notes as to when you'd be available for an engineer visit. As our tests aren't showing any underlying fault with the network, I believe this would be the best course of action. Smiley
Give me a nudge on here once that's been done and I'll get the fault raised as soon as possible.
KBD
GEA Test Detail
Circuit ID NA Service ID
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 34.9 Mbps
Upstream Speed 20.0 Mbps
Appointment Required NA
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Cross Talk Not Detected
Estimated Line Length In Metres 434.6
Upstream Rate Assessment Very Good
Downstream Rate Assessment Reasonable
Technology VDSL
DP Type External
Profile Name 0.128M-67M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2021-08-19T15:45:00
Parameters MIN MAX AVG
Down Stream Line Rate 34.9 Mbps 66.6 Mbps 63.6 Mbps
Up Stream Line Rate 19.9 Mbps 20.0 Mbps 19.9 Mbps
Up Time 732.0 Sec 900.0 Sec 899.7 Sec
Retrains 0.0 3.0 0.0
 Adam
 Plusnet Help Team - Leeds
brazclapz
@adam945
Thanks for the reply, I completed the Broadband Troubleshooter.
TheMightyAJ
Fixes: 126
Hi @brazclapz,
I'm sorry to hear you've been experiencing issues with your speeds over the last day or so. Just before we look at getting an engineer out, I can't see any notes on the Troubleshooter to confirm if you've been able to test the router whilst it's setup in the test socket in the property - have you had a chance to do so yet? For reference, we have a guide on this here.
Please let us know and we'll pick the case back up for review as soon as possible.
 Alex H
brazclapz
Hi, @TheMightyAJ
This morning I setup the router into the test socket & found that the connection was back to normal speeds, after moving the router back out of the socket the speeds have remained. The downstream now states 65.83Mbps.
LaurenB
Fixes: 131
Hi @brazclapz, thanks for getting back to us, I'm pleased to see your speed has gone back up again.
Should you have any further issues, please just get back to us.
 Lauren Barry
brazclapz
I'm now experiencing wifi issues. Devices connect but says no internet access. I've tried restarting router & refreshing the smart wireless but it's still not accessing the internet. My wired PC connects just fine with no issues.
Could there be a fault with the router itself?
adam945
Fixes: 113
Hello @brazclapz
Thanks a lot fopr reaching out and I'm sorry to hear that you've been having issues with your internet connection. Is this problem ongoing? Tests all appear okay on my end this morning.
 Adam
brazclapz
Hello @adam945,
Thanks for the response the issue seems to have resolved itself over night.
adam945
Fixes: 113
Great stuff @brazclapz
Feel free to reach out if you have any further issues / queries. Smiley
 Adam
