Static IP cost
lstegall
Static IP cost
Hello - I unknowingly added a static IP to my account.  It didn't show the cost, however it has charged me a £5 setup fee.  Is this a one off fee, and there is no recurring fee going forward?
Tags (3)
4 REPLIES 4
RealAleMadrid
Fixes: 68
Re: Static IP cost
@lstegall  That's it, a one off £5 fee, no monthly rip off like some other ISPs😀
How did you unknowingly set it up?
lstegall
Re: Static IP cost
Thanks think i was just seeing what it would cost and added it.
I did try to remove it, but the browser hung so don't think I did, can you check if it is still static as I have paid the fee so will keep it then.
lstegall
Re: Static IP cost
looks like it is still configured, thanks!
nsi-ltd
Re: Static IP cost
Getting static IP nowadays is like gold-dust.  Plusnet are great as they only charge a setup fee, and no continued monthly rip-off that you get elsewhere.  Also, most ISPs will only offer static IP on business accounts, so a double whammy!
As you have it now I would recommend you keeping it.  As the world becomes more connected it opens up the possibility to putting your own devices on the Net, without traffic going via a manufacturer's server.
Regards,
Steve
