Speeds Still Dropping When Downloading
purplecat123
Hi
New to Plusnet
But after a few months, download speeds are still dropping way below the minimum.
I have screen shots of the speed drops. And It it not getting any better...
I am using an ASUS DSL-AX82U on Windows 10... It was still happening on the router sent to me Tinternet 4.jpgTRinternet Again 3.jpg
Didn't have this problem with my previous provider
12 REPLIES 12
purplecat123
Re: Speeds Still Dropping When Downloading
pvmb
All Star
Fixes: 13
@purplecat123
ADSL? VDSL? FF? It's been posted in Full Fibre but...
Fixes: 374
@pvmb Despite this topic being on the Full Fibre board, I suspect it is VDSL.
purplecat123
Full Fibre 900 24 month cont
Fixes: 374
@purplecat123 That sounds strange. WHEN  the images get released, maybe we can advise. Until then, we can't. You could always ring Support, but I doubt you would get a useful answer.
Fixes: 374
Right, images released. I am assuming these are game/program downloads, in which case, the speeds are dependent also on the servers said downloads are coming from.
Can you please attach a copy of the result from https://www.speedtest.net/ . Use the 'paper clip' bottom left of the reply window, rather than embedding the result.
purplecat123
Its coming back, with 1.1gb
But it has nothing to do with steams servers. I've tried changing locations and so but the speed drops still happen
This has never happened on any previous provider, it even happens when using GOG (good old games) thats why I changed, for the increased speed and supposed reliable service
But the speeds are dropping below minimum as you can see
Must be a line problem maybe an account problem?
Fixes: 374
If the Ookla test is coming back with your quoted speed, then I am sorry, but it is not a line or account problem, it is as I said a sending server issue.
I do very little large file downloading, only have a 100Mb connection, but do see a 'slow download' on the few occasions I down a 'big' download. FYI, I am not on a PN connection.
njay
It could be steam client as quick search comes up with Limit bandwidth and Throttle downloads while streaming settings.
Have these by any chance been set on by a steam client upgrade?
seebee
Fixes: 9
Its not just the units is it? One of those steam pictures say peak of 79.7 MB/s which is 637.6 Mb/s which doesn’t sound too bad for a 900 Mb/s service.
Fixes: 374
Hadn't spotted that, @seebee  - thanks.
markhawkin
Aspiring Champion
Fixes: 20
There is a bit more to this than might be obvious at first glance.
The most obvious question is where Steam's servers are and given the round trip time, how fast they can send the data (noting the difference between Bytes of data and bits (per second) in the service speed).
The second factor is what Steam does with the data once downloaded (perhaps decompresses it or installs it) so how fast can the PC take and deal with the data from Steam.
I'm surprised that Speedtest.net says 1.1Gb/s with a router with Gigabit Ethernet connections. I would have expected a limit of perhaps 950Mb/s (even allowing for the Plusnet service to be over provisioned for 900Mb/s).
That sounds more like fast.com (perhaps more correctly called flattery.com )
