Speed
cfcws
Speed
My 150 service consistently runs between 90 and 95.
I have tested it using Ethernet and Wifi and the automated line check says there is no problem and it has reset the line.
I know 80 is the minimum so do I just have to accept it as I thought the full fibre was supposed to give full speed given that the excuse used to be the old copper wires.
6 REPLIES 6
Fixes: 585
Re: Speed
@cfcws
That sounds suspiciously like a faulty ( or cat5 only ) cable, which is limiting the speed to 100Mb.
What does the Hub 2 status screen say for the connection speed ?
cfcws
Re: Speed
Thank you I will check that later.
I may have mixed up my cables.
cfcws
Re: Speed
WAN speed is100 on the status page but the current cable says Cat5E.
Although I am not sure it is the original cable.
Could it be anything else?
Fixes: 585
Re: Speed
Well that's the problem! Now we just need to work out why.
Does that cable have 8 cores ?
First thing is to try a different cable between the WAN port on the router and the ONT.
You're looking for a WAN speed of 1000Mb on the status page.
cfcws
Re: Speed
It was the cable although I am not sure why as it seemed the same but obviously it wasn't.
Thank you for your help I would not have thought the cable could be the problem.
Fixes: 585
Re: Speed
A faulty cat5e cable can cause the speed to reduce to 100Mb. A Cat5 cable has 4 cores and will operate at 100Mb, a cat5e has 8 cores and is capable of 1000Mb. If there's a bad connector or a break in one core , a cat5e cable will still work but the speed will reduce to the cat5 max of 100Mb.
