Solid orange light on router
paulhampson83
Have a solid orange light have fully reset route still won’t reconnect
Tags (1)
1 REPLY 1
Fixes: 1,495
Re: Solid orange light on router
Log in to the hub by putting 192.168.1.254 in the address field of your web browser.
On the broadband page (I think, you may need to look through the pages to find it, depending on which hub you have) you should find the username. If it’s [email protected] then it hasn’t configured itself.
Remove the DSL cable.
Change the username to your account username in the form @plusdsl.net.
Enter your account password.
Plug the DSL cable back in.
If it doesn’t try to connect select Connect (again you may need to look through he pages to find it).
If that doesn’t work.
Contact Plusnet
