SoGEA to FTTP
deano7777
SoGEA to FTTP
I switched my router to PPPoE a couple of weeks ago, to check it was all working - which it has been.
FTTP was installed 3 hours ago, 3 green lights and engineer said that it's all working. However I'm getting PPPoE time outs. I assumed as it worked with the SoGEA connection it would be just plug and play.
Plusnet support have said it's a router issue.....I use a Fritzbox router
Does the authentication on FTTP get set up later on than the connection? I'm at a bit of a loss really what to do next.
19 REPLIES 19
Fixes: 1,495
Re: SoGEA to FTTP
It's totally different - you're SoGEA would have used the inbuilt DSL modem and FTTP doesn't need that.
You'll need to configure the router to reflect this and use WAN port and not the modem port.
Fixes: 382
Re: SoGEA to FTTP
@deano7777 Which port on the Fritz are you using - it needs to be port 1?
deano7777
Re: SoGEA to FTTP
@dvorak   My SoGEA was using the inbuilt DSL until a couple of week ago, but as per my first line in my post
Which worked fine for my SoGEA connection it is now not for the FTTP. The only differance is now the ethernet goes into the ONT and not the BT FTTC modem
deano7777
Re: SoGEA to FTTP
@jab1 Yep port one
Fixes: 382
Re: SoGEA to FTTP
Have you powered off and restarted the Fritz!box, so it picks up the new settings?
deano7777
Re: SoGEA to FTTP
It's had a couple of reboots, not full power off and back on though. I'll do that now.
deano7777
Re: SoGEA to FTTP
Though my Mac and Linux devices also wont connect with PPPoE directly connected to the ONT either
Fixes: 579
Re: SoGEA to FTTP
@deano7777 that sounds like your FTTP connection hasn't been completed by BTwholesale yet.
Have you received confirmation from PLusnet that you order is complete ? If you have then I suggest you call customer services
deano7777
Re: SoGEA to FTTP
that's what I thought , but when I called plusnet support they "checked" and advised it should all be working. As I was using a 3rd party router they'd not heard of suggested it was that 😂
I advised them I was getting PPPoE error Timeout
and asked if BT still had work to do.
Fixes: 382
Re: SoGEA to FTTP
Just as a point  of interest, I thought the installation engineer was supposed to verify the connection was OK before leaving - I know mine did.
deano7777
Re: SoGEA to FTTP
I've literally just had this as a txt
The Openreach work has been completed. Your service should go live on the date given by your Service Provider. Please refer to them if you have any questions.
Now
The wait continues then......
deano7777
Re: SoGEA to FTTP
He said the fibre connection was working and connected and I'd have a decent speed.
I guess he's getting all the leg work done and then going to the exchange ? is that even needed these days ?
Fixes: 382
Re: SoGEA to FTTP
He should have asked you to try the connection on your laptop/desktop before leaving - and no he does not need to visit the exchange, FTTP does not go through it.
Fixes: 579
Re: SoGEA to FTTP
@deano7777 no, there's no need to go to the exchange.
Aa @jab1 said, the engineer should have checked that the connection was working with your router
