Slow speeds
HighHopes
Slow speeds
I’ve recently joined plusnet after moving house but the speeds I’m getting have been somewhat disappointing.
initially my speeds were between 1 and 12Mbps. After an engineer replaced my master socket it’s now a steady 12 but won’t go any higher.
The router’s plugged into the new master socket and I’ve run speed tests using Ethernet.
Any thoughts would be appreciated.
15 REPLIES 15
HighHopes
Re: Slow speeds
Fixes: 385
Re: Slow speeds
Is your username  and password correct, or is it showing as '[email protected]' in your router?
HighHopes
Re: Slow speeds
Username and password set to my values
Fixes: 385
Re: Slow speeds
Ok, that rules that that out. Any chance of posting a screenshot of the Help Desk Page?
HighHopes
Re: Slow speeds
Which page is that?
Fixes: 385
Re: Slow speeds
Which Hub have you got?
HighHopes
Re: Slow speeds
Hub Two
Fixes: 385
Re: Slow speeds
A picture paints a thousand words:
HighHopes
Re: Slow speeds
Fixes: 385
Re: Slow speeds
I would report a fault at https://faults.plus.net
Fixes: 1,662
Re: Slow speeds
I'm really sorry to see you're having speed issues at your new house. I can see the engineer we arranged was from a company called Qube and they resolved a wiring issue by fitting a new master telephone socket, but I've tested your line today and the tests are still definitely showing a problem, so I'd like to call out Openreach to take a closer look.
Could you reply to the ticket we've logged on your account Here with when you'll be available for a further engineer visit? If you can post back once you've responded, I'll make sure we book the engineer as soon as we can.
HighHopes
Re: Slow speeds
I’ve responded.
Fixes: 1,662
Re: Slow speeds
Awesome thanks, I can see we've booked the engineer and updated the ticket with the appointment details.
Let me know how it goes.
HighHopes
Re: Slow speeds
The engineer has visited and reset the line. Speed has increased to around 20Mbps, which apparently is the best I’m going to get.
Thanks for the help.
