Slow fibre speeds
Kanti49
Slow fibre speeds
Hi
My download speeds are below the minimum guaranteed speed and my line speed is only 38.4Mbps.
  • Product: Unlimited Fibre Extra
  • Estimated Download Range: 40 - 57Mbps
  • Estimated Upload Range: 9 - 13Mbps
  • Minimum Guaranteed Speed: 36.4Mbps
  • Current Line Speed (Download): 38.4Mbps
Can someone check this to see if there is a fault.
Thank You
Kantibhai
9 REPLIES 9
Fixes: 334
Re: Slow fibre speeds
Welcome to the forums, @Kanti49 . From the details you have provided, Your current line speed is above the minimum (not by much), although it is below the estimated possible.
How long have you been with Plusnet?
Kanti49
Hi
Only 5 days but the line speed started at 78Mbps and deteriorated since. I was also getting much better speeds with sky.
Fixes: 334
Ah - I wonder. What does your router show as your user name?
Kanti49
I will have to check when I get home.
Fixes: 334
OK. I will be around till about 8PM, but maybe a Help Team member will pick this up and check before long. If they haven't, there are some checks we can run.
Kanti49
Brilliant thanks for your help.
adam945
Fixes: 113
Hello @Kanti49
Thanks a lot for reaching out and I'm really sorry to hear that you're having issues. While the speeds on your line are above those that were guaranteed on your contract, they're still pretty low in contrasty to those which you were told
Tests on the line aren't picking up on any underlying issues with the service, though an RRT shows that line issues are present, and that the speeds are i n and around 39.9 Mbps.
Going forward, please have a read through our Troubleshooting Guide to see if you're able to resolve the issue sooner. When testing, please remove the faceplate from your Master Socket, and connect your router directly into the test socket which lies behind it. Avoid using any extension cables / sockets too if possible.
Troubleshooting Guide - https://www.plus.net/help/broadband/connection-troubleshooting/
See how you get on, and if the problem persists, head across to faults.plus.net and raise this issue with our Technical Support Team. In the Additional Information section, pop in some dates and times that you'd be available for an engineer visit, our Technical Support Team will then be in touch, though feel free to reach out when you've done it and I'll be happy to get the fault raised with our suppliers.
 Adam
 Plusnet Help Team - Leeds
Fixes: 334
@adam945 Thanks for picking this up
@Kanti49 I'd still like to see if I can spot anything, so when you have time, let me know.Smiley
Kanti49
HI
This is my dads broadband and he is older and not very tech savvy.  I will have to wait until I can go and try the troubleshooting steps before contacting your technical support team if things don't improve.
Thank You
