Static but sudden drop in download speed, help please?
oakbydesign
Hi
I have raised a ticket after a telephone call on Saturday.
We have had good uninterrupted fibre broadband for months and no issues.  65Mb/18Mb - all good.
On Wednesday 22nd Sept we noticed a sudden drop to 16Mb down but still getting 18Mb up?
I have tried a new router, cable and filter in the normal and test ports on the BT socket, no luck.
I have attached a copy of a report showing the issue.
I have dialled 17070 - noise test, no noise on both the normal and test sockets.
Not sure if the line needs resetting (if this is a thing) but any help would be appreciated.
Richard
15 REPLIES 15
Fixes: 488
Re: Static but sudden drop in download speed, help please?
@oakbydesign  have you recently changed to a static IP ?
If you login to the member centre and select the 'Broadband' tab https://www.plus.net/member-centre/broadband
what does it say for 'Current Line speed' ?
oakbydesign
Thanks for quick reply!
See attached
oakbydesign
@MisterW - We thought we were always on a static IP.
Can I check to see if we are or if it been changed?
(EDITED - just checked and we are on a dynamic IP.      I thought we were static as when we typed 'what is my IP address' it always said the same - unless I'm barking up the wrong tree)
Fixes: 488
@oakbydesign your IP address may not change very often, even its dynamic.
What does the member centre say for current line speed?
The current line speed, if its,wrong, will affect accountsxwith static Ip's or with the firewall enabled
oakbydesign
Current line speed says: (Download): 73.8Mbps
We have a dynamic IP.
I am assuming we do not disable the firewall?
Fixes: 488
Ok, so the problem isnt what i thought it might be.
Was your speed test wired or wireless?
oakbydesign
Hi
Both wired and unwired, in both normal and test sockets, is around 16Mbps UP and 18Mbps DOWN.
Fixes: 488
In that case I'd raise a fault at https://faults.plus.net quoting the results of a wired btwholesale speed test
adam945
Fixes: 113
Hello @oakbydesign
Thanks a lot for reaching out and I'm really sorry to hear that you're experiencing slower speeds than what you're used to. Although all of my tests on the line this morning have found that the line is syncing at 73Mbps. It also appears that you've done quite a bit of Troubleshooting yourself so the only thing I'd be able to suggest here is a Qube Engineer visit.
Qube engineers can't make any changes to the Openreach Network, but specialise in the i9nternal environment to see why your speeds might be quite low. Please respond to the open Ticket on your account, stating your availability and I'll be arrange an appointment that suits you. Smiley
Give me a shout on here once you have responded and I'll be happy to get it sorted.
 Adam
 Plusnet Help Team - Leeds
oakbydesign
Adam
All replied, thanks.
Richard
adam945
Fixes: 113
Ah great stuff! What turned out to be the problem?
 Adam
oakbydesign
What?
You asked me to reply to the ticket ending xxxx99831, so I did.   Did you get it?
Richard
adam945
Fixes: 113
Massive apologies @oakbydesign - it's been a long day!
I'll be happy to answer your questions on the Ticket here as it may benefit other users.
1. There's no charge for a Qube Engineer visit, regardless of where the fault is found. Openreach Engineers have access to the external network, whereas Qube engineers specialise in the internal environment. As our tests aren't showing any external faults, I reckon this is the best way forward for now. We can still arrange an Openreach engineer appointment later on if needs be.
2. Looking through your notes above, you've basically done everything we'd ask you to anyway, so at this stage, again I'd recommend an engineer visit. Let me know if you're still happy to go ahead and I'll get one arranged for the earliest date / time available. Smiley
 Adam
oakbydesign
Adam
Upon checking our speed again this morning, I'm pleased to say our speed is now back to normal.  Weird.
Nothing has changed at our end.
Although good news, may I ask if the line has been 'reset' or can you see anything that I can't, that may have 'solved' the issue?
Regards
Richard
