Slow Download , high upload, high ping
Nr352pa112
Hello, i have the 500mgb package and the speeds i am getting are 39ping ,  96mgbs download , 74upload. then i test again and the speed goes up 50 mgb. then i test straight after and its dropped say 50 meg. these tests are all WIRED ethernet tests from a high spec laptop.
also have the latest router that bt installed the hub 2 or whatever it is called.
bt been out once and said nothing wrong there end. i have had it installed 16 days approx. plus net say nothing wrong there end.
if i reset the router it tests at like 480mgb straight away but continually drops down to 100mgb over an hour and keep there till i reset the router.
Help please
13 REPLIES 13
willcutforth
Fixes: 113
Re: Slow Download , high upload, high ping
Just so we all have a better picture, can you send in pictures of where the router is located etc and how it is set up? I can't test sync speed on full fibre you see. I know the guys are also going to ask to see the router stats so are you able to log into the router and give us the stats from there?
"Advanced Settings" > "Technical Log" > "Information" page of the router.
 Will Cutforth
Fixes: 581
@willcutforth i thought you (ISP's) could now run a speed test directly to the ONT. Only thing it is an intrusive test i.e it drops the users connection for the duration of the test.
That's a bit strange...
Nr352pa112
router setup was done by BT please see attached photographs.
Please see below the router information20231219_124112.jpg20231219_124912.jpg bit you asked for.
Product code:Plusnet Hub Two
Serial number:+108419+2335007376
Firmware version:v0.10.00.04201-PN
Firmware updated:5-Dec-2023
Board version:R01
GUI version:1.9 16_08_2022
DSL uptime:-
Data rate:1000 Mbps / 1000 Mbps
Upstream error control:Off
Downstream error control:Off
Data sent / received:349.2 MB Uploaded / 2.9 GB Downloaded
Broadband username:<Redacted>@plusdsl.net
2.4 GHz wireless network name:PLUSNET-6JC36H
2.4 GHz wireless channel:Smart (Channel 1)
5 GHz wireless network name:PLUSNET-6JC36H
5 GHz wireless channel:Smart (Channel 36)
Wireless security:WPA2
Wireless mode:Mode 1
Firewall:On
MAC address:DC:F5:1B:38:83:88
Software variant:-
Boot loader:0.1.7-PN (Thu Nov 30 09:45:22 2017)
Moderator's note:
Personal information removed from a public forum (to an area that staff can see).
Nr352pa112
tell me about it. please see photo of the wired speed test carried out. 20231219_125220.jpg
Fixes: 581
@Nr352pa112 thanks for that, at least it shows the cable from the router to the ONT is correct and is a gigabit link
The stats dont show the uptime for the router ? roughly how long is it since you last reset it ?
Is there any possibility that there is a device connected wirelessly that is downloading a lot of data ?
or possibly the laptop trying to download updates whilst doing the speed tests ?
@MisterW The stats dont show the uptime for the router ?
The answer you seek is found here  Home page > Status
Network Uptime - active PPPoE login
System Uptime - how long the hub has been switched on.
Might speedtest cli be better to use here?
@Nr352pa112  do you get similar results using a different speed tester ? - such as Waveform Internet Speed Test
On my connection have never found the BT Wholesale "Performance Test" to be anywhere near accurate !
Nr352pa112
Its a work laptop. local government issued . so alot of restrictions etc (no downlaoding apps, cannot run CMD prompt etc)
i thought it was i7 buts its not. spec below.  could it be the laptop causing non accurate speed tests?
Device name LT22508
Full device name LT22508.EastSuffolk.local
Processor 12th Gen Intel(R) Core(TM) i5-1245U 1.60 GHz
Installed RAM 8.00 GB (7.69 GB usable)
Device ID 77D6011A-3E46-4386-9A61-28F286676B81
Product ID 00329-00000-00003-AA696
System type 64-bit operating system, x64-based processor
Pen and touch No pen or touch input is available for this display
Nr352pa112
Fixes: 581
@Nr352pa112  Aah! My guess that its almost certainly running VPN software and so any internet access (including the speed test) will be via the VPN.  That may well be throttling the speed...
Nr352pa112
@Nr352pa112  Aah! My guess that its alomost certainly running VPN software and so any internet access (including the speed test) will be via the VPN.  That may well be throttling the speed...
okay then. that makes sense! sorry for wasting all of your time! thank you for helping!
Fixes: 581
@Nr352pa112 you could confirm if a VPN is active by going to https://www.whatismyip.com/ in a browser and comparing the IP shown with the one shown on the router status page. If a VPN is active , they will be different
Probably not useful now if the VPN is the problem but as @Dan_the_Van said earlier the Ookla speedtest cli (https://www.speedtest.net/apps) is the most consistent test for higher speeds. Problem is you're probably not allowed to install it! The browserbased one is https://www.speedtest.net/
Nr352pa112
you were right.  ip addresses are different as is locations etc
