Sites only load when using VPN
- Full Fibre
- Re: Sites only load when using VPN
- « Previous
- 1
- 2
- Next »
10-01-2025 8:43 PM
Following on from the above post, it might be interesting to see the result of a tracert to one of the 'misbehaving' sites?
Message 16 of 17
(630 Views)
11-01-2025 2:31 AM
@gcbmendham have you ever tweaked your router's MTU to a non standard setting (perhaps for connecting to the Sony Playstation network, or similar), as having a misconfigured MTU can cause the symptoms you are reporting.
Message 17 of 17
(592 Views)
- « Previous
- 1
- 2
- Next »
- Full Fibre
