Signal strength rapid drop outs
CoolerKing
Just had full fibre installed on 5th December 22. Everything fine until last few days when signal strength constantly dropping out then coming back. Speed test showing average 130mb but streaming is pausing and signal strength icon is barely filled in.
4 REPLIES 4
Fixes: 116
Re: Signal strength rapid drop outs
@CoolerKing
Are you testing on a wired connection or WiFi?
If WiFi is causing you problems with the service then the service itself may be fine.
CoolerKing
The WiFi signal shows high.
The signal strength shows low.
Speed test shows 130 mb average using WiFi but streaming via Chromecast is buffering.
RealAleMadrid
Fixes: 68
@CoolerKing   The Wi-Fi signal shows high, but the signal strength icon shows low. Where are these indicators and on what devices?
CoolerKing
Mobile phone. Chromecast to TV.
