Router Auth fault
- Full Fibre
- Router Auth fault
Router Auth fault
11-10-2025 11:59 AM
I had a router auth fault, Faults2.
Moved house bringing my old router & account with me.
The house previously had no broadband so open reach booked to come fit a plug.
Engineer arrived and surprised to see fibre had been fitted externally already but no internal plug.
He has fitted a plug and tested all ok his end.
Router still showing solid orange spoke to customer service who advised it’s an auth fault, tried resets etc.
Currently another engineer booked but given the first guy tested it as fine, I’m not sure what additional use the engineer will be.
After some googling I found this thread:
https://community.plus.net/t5/Full-Fibre/Strange-apparent-router-authentication-failure/td-p/1888919...
I wondered if I might be facing the same issue?
Message 1 of 2
(435 Views)
1 REPLY 1
Re: Router Auth fault
12-10-2025 9:09 AM
@Archtronics wrote:
When you say they "ftted a plug" that doesn't sound like full fibre.
Is there a box like this
https://neosnetworks.com/wp-content/uploads/2024/02/optical-network-terminal-ont.png
Message 2 of 2
(358 Views)
