Request a GEA test for my line please
MaximusVR46
Re: Request a GEA test for my line please
so its not even been what the BT engineer advised of 5 days and plusnet has sent an email saying i am achieving the minimum speeds of 39! and closed the ticket when I had stated on the ticket please do not close it.
I have screenshot evidence from BT wholesale speed test of me getting 36-38 speeds since the BT engineer visit which is appalling for the fibre extra package.
adam945
Fixes: 113
Thanks a lot for reaching out again @MaximusVR46
The reason why one of our Technical Support Agents has closed down the fault ticket is because they likely ran a GEA test this afternoon and found results similar to mine which I'll post below. Download sync speeds on our end are coming through at 47Mbps today, which is within the estimates provided when you initiated your contract with ourselves.
Download: 44 - 59Mb
Upload: 8 - 13Mb
Minimum Guaranteed Speed: 39.1Mb
You should bare in mind that when you're running speed tests on your devices, it's giving you the throughput speed, and not the sync speed, which we're contractually obliged to provide. Throughput speed can be dependant on a wide range of things such as the number of other devices connected, WIFI interference, WIFI channels and bands etc - this is why we cannot guarantee it.
The best way to see the sync speed for yourself is by going onto your Plusnet Hub One manager - Troubleshooting - Helpdesk - Data Rate, Feel free to pop a screenshot of that page onto this thread (covering the username) and we'll have a look. Smiley
KBD
GEA Test Detail
Circuit ID NA Service ID
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 47.1 Mbps
Upstream Speed 13.7 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Cross Talk Not Detected
Estimated Line Length In Metres 716.3
Upstream Rate Assessment Good
Technology VDSL
Current 15Min Bin Retrains 0
Last 15Min Bin Retrains 0
DP Type External
Profile Name 0.128M-80M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2022-01-29T09:00:00
Parameters MIN MAX AVG
Down Stream Line Rate 50.0 Mbps 51.4 Mbps 50.3 Mbps
Up Stream Line Rate 11.2 Mbps 11.6 Mbps 11.3 Mbps
Up Time 860.0 Sec 900.0 Sec 899.4 Sec
Retrains 0.0 1.0 0.0
 Adam
 Plusnet Help Team - Leeds
MaximusVR46
Hi, Would it be possible please for another GEA test. Since my last issues I have managed to get my line quite stable giving BTWS speed tests between 50 and 55 down. For the past week..ish speed tests have dropped and been giving between 40 - 45 down. My modem/router (picture attached) shows its always syncing at 48998. This was syncing higher giving me the higher speed tests but now never connects higher than 48998. Have I been banded or a line profile?
I believe i may be banded at 50mb.
I have tried the plusnet modem / router and several other modems with no luck.
thanks
Fixes: 1,652
I haven't been able to run a GEA test as there's an open service problem in the area which our suppliers are working on, but looking at a different diagnostics tool I can see that your speed is banded to 49mbps. The full profile is "Downstream: 0.128M-49M with Retransmission (Low). Upstream: 0.128M-20M with no error protection"
I've arranged for your line to be reset which should happen within 3 working days however depending on what the service problem actually is and the work undertaken, you may still have issues.
Let me know how it goes next week and I can try running another GEA test for you.
MaximusVR46
Hi @Gandalf ,
Thanks for the info and I am glad I was correct with my own diagnosis with being banded. Do you know the reason why this banding was applied?
There is a lot of BT engineers / activity in my area this week.
Will keep you posted.
Cheers
Fixes: 1,652
I can't see why the banding was applied as line tests aren't running due to the open service problem, but the banding could very well be an unexpected side effect of the work the engineers are carrying out.
Cheers
