Red LOS Light on ONT, Orange Router - all cables are correct
socklobster
Just switched from plusnet landline + broadband to full fiber and once engineer left it worked for around 1 hour before cutting out
There is a red LOS Light on the ONT,  Hub Two is glowing orange - all cables are correct and I can connect but have no internet
Thinking i need an engineer visit as it will be a wiring thing - I work from home so this is not a happy time
4 REPLIES 4
Fixes: 478
Re: Red LOS Light on ONT, Orange Router - all cables are correct
@socklobster  Welcome to the Community Forums.
If you have only gone live today it might be that Plusnet have not fully set up your account. If you have received a text saying that it’s all set up then report a fault. See. https://www.plus.net/help/report-a-problem/broadband/#broadband
Fixes: 478
@socklobster
Another thought as you are trying to work, have you checked whether the FTTC circuit is still working?
Fixes: 579
@socklobster LOS indicates a fault in the fibre circuit. About the only thing you can check yourself  is that the fibre connection to the ONT is 'clicked' home and hasn't come lose. Other than that , it's raise a fault as @Baldrick1 says
MatthewWheeler
Fixes: 503
Hi @socklobster
I'm sorry that your connection wasn't working after you upgraded to Full Fibre.
I can see an engineer went out on Saturday and fixed a fault with the fibre wiring.
Has your connection been okay since?
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
