Quite frankly 80/20 stinks!
- Full Fibre
- Quite frankly 80/20 stinks!
27-04-2012 11:17 PM
Tonight I thought to give the old speetest a whirl:
Not pretty.
What with all the shaping and [Censored] I am ready to try even chuffing talktalk right now!
Sort it out guys this place is going to hell.
[Moderator's note by Dick(Strat) Title edited as per forum rules.
Re: Quite frankly 80/20 sucks balls!
28-04-2012 12:41 AM
I would never use TalkTalk, though.
28-04-2012 1:03 AM
28-04-2012 1:13 PM
28-04-2012 1:28 PM
2. It's not costing you any extra money.
3. You can raise a ticket regarding the performance issues (make sure you make it clear that it appears to be an issue with the 80/20 trial and be patient while they try to fix it).
4. You can request to go back to the standard 40mb service at any time (previous performance will amost certinly be restored).
28-04-2012 5:37 PM
It's a trial - the point of trials is to find out if it works and before applying to be part of a trial you should weigh up the risks. If you are not prepared to accept the risks it's simple - don't apply to take part!
PS. The subject you've given to this topic is not acceptable on these forums, I've reported your post to the moderators and I'm positive they will be changing it to something more acceptable as soon as they get to it (unless you change it yourself first).
Re: Quite frankly 80/20 stinks!
12-05-2012 10:03 PM
12-05-2012 11:21 PM
I'd tend to assume you were previously on 40/2 (the standard Plusnet Fibre speeds) rather than 40/10 (only ever available to the lucky few on the early FTTC trial) as this would be entirely consistent with an upload of 1.7mb/s. If your download was previously well below 37mb/s (about the maximum realistically for a 40mb service) then it is unlikely that you'd see any real increase on 80/20.
The location of cabinets is entirely based on BTs old infrastructure (how the main telephone cables are routed from the exchange to your property), your line will only ever go to one specific cabinet as this is how the cable was originally installed and, unfortunately, it is not always the nearest cabinet to your property. As your telephone line is not in any way connected to the nearer cabinet there is no way of providing you with a FTTC service from that cabinet.
14-05-2012 4:24 PM
18-05-2012 8:47 PM
Still uses the same phone line, same cabinet, still provided by BT wholesale maintained by BT Openreach = no difference! The only way to truly get away would be to get Virgin cable or mobile broadband!!
18-05-2012 9:06 PM
Quote from: Spesh Virgin cable
[Rant]No thanks! Please wash your mouth out.[/Rant]
Having experienced the absolutely worst customer service ever at the hands of these criminals some years ago before being 'rescued' by PlusNet I would NEVER use them again.
19-05-2012 11:53 AM
Quote from: Spesh Isn't it amusing when people say that they're not getting the speed they expected and so are tempted to change to BT/Sky/TalkTalk/bulldog/madasafish etc.etc. thinking that it'll make a difference?!
But not the same traffic shaping, some no doubt worse, others with no traffic shaping only contention......
Edit: Traffic shaping shouldn't affect speed test results, and also loads of ISP's are having speed related issues with 80/20 connections, which most likely means it's not a Plus Net related problem.
24-05-2012 9:23 AM
Not so, Sir! There is (or, can be) a difference.
I was previously with PlusNet on an ADSL service which could not achieve more than 6Mbps. I migrated to Zen Internet where I was consistently getting 10Mbps. Same wires, Same cabinet, same exchange.
The speeds to which I refer are not periodic speed tests, they are from continual monitoring of my line conditions for SamKnows.
- Full Fibre
