Query about fibre upgrade and concurrent landline/fibre + keeping BT phone number
- Full Fibre
- Query about fibre upgrade and concurrent landline/...
04-03-2026 1:54 PM
Hi, I'll try to be quick!
Situation: I've ADSL via Plusnet + BT Landline number. Will lose "soon" due to switchoff. I should be able to get FTTP.
What I want: Fibre via Plusnet / BT number kept with VOIP provider.
Question: Order of things and concurrency.
Googling I've read a number of tales of woe about losing numbers and so on when losing the landline on the plusnet forum when they get a fibre upgrade but I just realised these people seem to have had their phone with plusnet NOT BT.
My ASSUMPTION was that when fibre is installed, BT/Openreach DISCONNECT the landline. Basically SWAP the service across while they are there. Google "AI" results have **explicitly said that is exactly what happens** when I search (a number of times!) but it's often wrong of course.
I've also read the simple way to do this is to just get the fibre installed THEN move the BT number to VOIP. Which sounds better but contradicts the above.
So Question. Is it quite possible (in fact better) to get fibre installed and just tell BT nothing, so that for a while I'll just have fibre AND my landline number? Then move my BT to VOIP once dust settles? Basically: Will a fibre install NOT affect my landline, other than disabling ADSL?
Re: Query about fibre upgrade and concurrent landline/fibre + keeping BT phone number
04-03-2026 2:23 PM
First thing to check is whether you can get FTTP or SOGEA (FTTC). If FTTP is available then you should be able to get that installed and keep your ADSL + phone line active - once FTTP is active then move your phone number to the VoIP provider of your choice, that will terminate the phone and hence ADSL. If only SOGEA is available then move your broadband to that, which will terminate your phone line too, and you will then have 30 days to transfer the number to VoIP.
If neither FTTP or SOGEA are available then you'll need to investigate 4G as very few ISPs offer SoADSL.
04-03-2026 2:37 PM
I'm fairly sure I can get FFTP, there are these boxes around installed a couple of years ago that look like a black cows udder.
Which is quite the metaphor, wonder if I invented it, Freud might have a field day with me ![]()
They run into neighbours homes and I know a neighbour has an ONT box from one.
OK well if I can keep both that's less stress. I've read quite a few people can have issues (not with plusnet) as well but I think it's often the case they are switching landline + fibre out/across from same provider, which I am NOT doing. BT forums have a number of people complaining about lost numbers, looks like as I can do it in two steps I should be OK (touch wood).
I rarely use my landline but it's handy for people to call me in Emergency if my mobile is off etc.
04-03-2026 2:42 PM
Use the following to check that Full Fibre is available. You're looking for WBC FTTP in the left column. If it's there what does it say to the right - One stage or KCI2?
Below the results window will be a narrative on the FTTP install - specifcally if any problems are expected.
For FTTP a new cable is run to your property. You lose the landline on the day of install as FF takes over your service. You then have 30 days to port the number to the VOIP provider of your choice. Note you cannot do this before FF is installed and working. You might have a few days downtime on the phone,.
If you try to move before the FF install this could cause the cancellation of your phone line and hance your broadband service which in turn can lead to the FF being cancelled.
04-03-2026 2:58 PM - edited 04-03-2026 3:10 PM
That doesn't need to happen if FTTP is ordered as an additional new service rather than as a regrade of the ADSL.
04-03-2026 3:03 PM
My result says
| WBC FTTP | Upto 1000 | Upto 220 | -- | Available | 1 Stage |
You see this is what's worrying, I've 2 "seasoned champion"s responding to my post and you are totally contradicting each other ![]()
BT had written to me with a letter about losing the service as I've landline/adsl split, trying to get me to move to BT.
To me, the more I think about it, if fibre is separate service I just "detach" the ISP part and convert it to fibre, so why does the landline need disconnected then, it's an additional service to the landline .. sigh..
04-03-2026 3:10 PM
The problem with ADSL is that it is always associated with a phone line - even if the ADSL and phone service are provided by different companies. Cancelling one will cancel the other - and as BT are closing their PSTN phone service down and moving customers to Digital Voice that will shut down your Plusnet ADSL. Worse, since VoIP needs broadband, BT will sell you their FTTP with Digital Voice.
If you were to transfer your Plusnet ADSL to Plusnet FTTP then you would lose your phone line, as that would go away when ADSL goes.
However, if you don't transfer the ADSL but get a new additional FTTP broadband connection then both can coexist until you cancel either the phone or ADSL.
04-03-2026 3:29 PM
We're not contradicting each other per say. I missed the part where you said you were on a BT landline and PN ADSL broadband. This complicates matters slightly.
BT Retail have been transferring their landline customers onto their Digital Voice service by area to prepare for the closure of PSTN in January 2027. Hence the letter from them.
My advice still holds good as such. Order FF from PN and when it's installed your BT landline will be terminated. However, you may be due early termination charges from BT.
The landline is going this year, one way or another so now would be as good a time to say bye bye. However it is possible to keep it for the time being if you're willing to pay. You order FF from PN but make it clear it's a new installation and not an upgrade.
This way the old service continues for a short time until BT move it to digital but you would be liable for ETC's from PN when the ADSL service is terminated and you lose any PN add ons like email.
04-03-2026 3:32 PM
I did something similar a while back, you probably need to phone in and VERY CAREFULLY explain that you want an additional service as otherwise you could end up compromised.
(In my case I was on BT landline with PlusNet ADSL and installed a NEW SOGEA FTTC line alongside as there's no FTTP here for a while)
Once my new line was up and running I cancelled the old ADSL, that didn't affect the BT phone line.
Shortly after I transferred my phone number to A&A which also terminated the BT landline.
04-03-2026 3:35 PM
"The problem with ADSL is that it is always associated with a phone line - even if the ADSL and phone service are provided by different companies. Cancelling one will cancel the other"
You see this to me doesn't make sense. If you've a BT phone service, why would cancelling ADSL cancel the phone service?
In post #2 you said
"If FTTP is available then you should be able to get that installed and keep your ADSL + phone line active - once FTTP is active then move your phone number to the VoIP provider of your choice, that will terminate the phone and hence ADSL"
Ahh wait it I needed to re-read that carefully and what you just said. You are suggesting i keep ADSL and Fibre concurrently.
Do you mean I then have TWO services with one plusnet account? ADSL broadband + fibre? So it's not an fibre upgrade, it's a totally new additional product purchase? That seems a bit mad and I fear something unforeseen might happen
In the portal there is just "contract details" and "current package" not "Your contractS" and "Your packageS" etc.. worrying:
I've a static IP, how could that work, it couldn't. I've also a plusnet email address and webspace, I don't want that lost either!
04-03-2026 3:35 PM
The Checker does indeed show you can get Full Fibre.
The boxes installed on the poles are called Connectorized Black Terminals (CBT). A fibre cable is plugged into this and then run to a property. At the property it connects to an external box called a Customer Splice Point (CSP). It then gets brought into the property to the Optical Network Terminator (ONT). This needs a power source. The router conencts via an ethernet cable so can go anywhere you're happy to run said cable.
You said you don't use the phone much. Have a look at A&A for VOIP - they are cheap if you don't make many outgoing calls. Note that VOIP does not work during power cuts unless backup is in place.
https://www.aa.net.uk/voice-and-mobile/voip-information/
04-03-2026 3:38 PM
"This way the old service continues for a short time until BT move it to digital but you would be liable for ETC's from PN when the ADSL service is terminated and you lose any PN add ons like email."
This is what I'm worried about. It's all pretty confusing (though I realise this is apparently BT's fault for forcing it).
There is obviously no physical reason they couldn't just turn off the ADSL and keep the land line working for a few months.
04-03-2026 3:39 PM
Cancelling the phone line does cancel the ADSL service. However, cancelling the ADSL service does not cancel the phone line. As I understand things an upgrade to Full Fibre does trigger a BT phone line cancellation but it's something to keep and eye on.
Your Static IP and add ons from PN should be unaffected by an upgrade.
04-03-2026 3:56 PM
I'm re-reading post 2:
"of your choice, that will terminate the phone and hence ADSL. If only SOGEA is available then move your broadband to that, which will terminate your phone line too, and you will then have 30 days to transfer the number to VoIP."
I'm not clear here. If I do the simple ADSL to FTTP upgrade, and this terminates the phone line, do I still get the 30 days?
The way this sentence reads it MIGHT be I only get the 30 days if it's SOGEA.
04-03-2026 4:02 PM
"Your Static IP and add ons from PN should be unaffected by an upgrade."
Ok thanks, but that's the upgrade. You said .. "This way the old service continues for a short time until BT move it to digital but you would be liable for ETC's from PN when the ADSL service is terminated and you lose any PN add ons like email."
So I've 2 options then?
1. Upgrade to FTTP, lose landline immediately, THEN contact VOIP guys within 30 days to try and get number (but I've read horror stories), lose phone number for days/weeks.
2. Keep ADSL, get a second package with FTTP, lose plusnet services, contact VOIP, transfer landine number, cancel ADSL, get hit (maybe) with some ETC cost from PN as Ive.. what .. a new parallel PN account by sounds of things. Not contract WITHIN the existing account.
Is this correct?
Sigh, it shouldn't be this complicated ![]()
This must be a nightmare for people who rely on a landline etc
- Full Fibre
